Originally posted by Beeg
View Post
2200mm C-119
I just did the number mining and a 1/10 scale gives you 3" dia wheels with a W/S of 68" and length of 115".Originally posted by Twowingtj View Post
If it could be scaled up so it had at least 2 1/2" wheels, it could be flown at our field.
Alot of cool "not done before" ideas here Freewing/FlightLineRC/MRC. Just sayin'.......
Now I know you really want it now cause those numbers definitely put this jet into the Giant class. :Scared:;)Warbird Charlie
Going to need a bigger vehicle :Confused:Originally posted by OV10 View Post
Good point! You know, if MRC were to produce a big B-36, I'd pick that over the B-58. And those BIG wheels would make it a viable candidate for grass fields. Could you imaging the sound with 6 props and 4 EDFs!!!! You would need a truckload of batteries to fly it.Originally posted by F106DeltaDart View Post
Naaah.. You just need a bigger B-36 to haul it to the field :);)
Seriously, it could be done in a 2.2m format using smaller 4S based motors turning 10" 3-balde props. Have the motors run in pairs to each side using 3 ea. 4000mah 4S lipos. No EDFs, just dummy pods. Nobody's done that mass produced in foam before.
I can hear the modding gears grinding on the both of you ! ! ! :Smug:Warbird Charlie
