Official Freewing 64mm High Performance Stinger Thread
    Originally posted by becevit
    Will 3300 mah 4c battery fit in this plane?
    By "4c" I assume you mean "4s". No, a 4s 14.8V 3300mAh Lipo battery will not CG in our Freewing 64mm Stinger 64. That's far more than it was designed to fly. Even if you could somehow get it to physically fit and meet CG, the wing loading would be high and you'd lose a lot of the fun factor intended for this lightweight and nimble sport jet.
  • Hemidoo
    Sounds fat to me , maybe others will chime in
  • becevit
  • Hemidoo
    Originally posted by Beachsideflyer
    Just ordered the 4s Stinger, does this model use a cheater hole? Couldn’t tell from the website and I hate cheater holes.
    No , straight up dude ....
  • Beachsideflyer
  • Hemidoo
    Originally posted by baddley
    Hi
    I am looking to get the high performance 64mm 4s stinger. The question I have is I have a few 4s 1350mah packs laying around from quad racing that need put too use. How hard will it be to obtain the CG for this and what should I get for flight times with not WOT flying too ?
    Thank
    Scott
    i've flown mine with a 1600 4s , get about 3 mins. no problem
  • baddley
    Hi
    Thank
    Scott
  • crankestein
    What is the ESC for this plane?
    Manual does not say anything. Throttle was reversed so it went to program mode and am not sure what changes took effect during that time period.
    And would like to know which make, model ESC or if anyone has a link the manual.
    thank you
  • Hemidoo
    Really like mine too ! Rips fast as heck once its up and rolling . I can get mine airborne off short grass on wheels but it sure does like a good head wind . 2200 admiral pro 4s stuffed in the battery box . It started out as a 3s but changed out the fan and esc
  • Len P.
    Woody218, I have about 30 flights on my Stinger, No Landing gear,( grass field) Using Admiral 2200 4s packs as well, Using a Spectrum DX6 with a Ar400 receiver, I spool it up about 80% throttle, give it a underhand toss at about 45 degrees up, and Away we go.Takes off straight and flat, I don't know why yours wants to roll to the left, Unless something is not lined up right with the motor assembly, Or something else, I had a Lemon gyro in mine on maiden flight, Then took it out as it did not need it. As far as the decals peeling off, Before I fly any plane, I airbrush them with Minwax Polycrylic, I used Semi-gloss on this plane. If you don't have a airbrush, You can use a 1 inch sponge brush, use as light a coat as possible, then use 2 coats. BTW, This is what I use for High and low rate settings for mine: Low rates: Aileron-60%, Expo-40%, Elevator-65%, Expo-40%, Rudder- 100%,Expo 0%. High Rates: Aileron-80%, Expo-35%, Elevator-80%, Expo-35%, Rudder-100%, Expo-0%. My Stinger flies perfect at these settings, And do Not use a 3s battery in this plane, I ran out of 4s one day, put a 2200 3s in it just to fly one more time, Nope,, Not enough thrust, veered in a nice wide arc into the field, and broke the nose off, Re-glued, and we fly again, But I like this plane So much, I ordered a spare, To have in stock, So far it is Still in the box, So I hope you get your torque roll problem figured out, As this is a Great little plane. Good luck!
  • Woody218
    I use a Lemon stabilized receiver in mine with the gyro turned on at launch, or else it will torque roll to the left. I fly mine with Admiral 2200 4s packs. Most of the decals on mine have peeled off. Great little flyer, speedy as heck, really fun to fly! When this one augers in, I will for sure get another!
  • rcflyer23
    Welcome to Hobby Squawk rcflyer23! Congrats on the Stinger. It is a great flyer if you've got a good deal of experience. It's a quick little bird and can get "small" really fast if you let it get too far away from you. The throws in the manual are pretty good. Do dial the ailerons down quite a bit. They are VERY effective. Good luck with you maiden.
    Well, I did get to maiden it. Unfortunately, I either had a brownout or some kind of other failure and she went in nose first at a pretty good clip.
    Thankfully it is nothing some steam, boiling water and glue can't fix. She may not be as pretty now but she'll still fly. Gotta give it to that foam it is pretty resilient. I agree while it was flying I was super impressed by the airplane. I'll have her flying soon enough.
  • rcflyer23
    Just received mine for Fathers day. Hoping to get out and maiden it today if the weather will hold out. I opted for the 4s version. Hope it flies well and I don't bring it back in pieces.
  • fhhuber
    EPO is the next best thing to Teflon for non-stick. then add the mold release agent from when they formed the EPO. If they missed getting some mold release off, the paint/deals are doomed.
  • Plane Addicted
    So I just madianed my 4s Stinger 64 tonight and the paint came off part of one wing panel. Is that normal? Other than that it was awesome!
    Originally posted by willwillwill718
    I am assuming you're using a Spectrum radio? If so, can you tell me your dual rate setup? I want to duplicate and like you, I don't go by MM like the site mentions.
    Welcome to Hobby Squawk will. I use a Spektrum DX9. I have mine set-up on a single 3 position switch. For my flying style, I use mainly the low and mid rates. I use low rates for launch. IMHO the ailerons are too effective at Motion's recommended rate. You may find different rates work for you.
    Low: Ail = 49% 50% expo, elev = 55% 45% expo, Rud = 70% 45% expo
    Mid: Ail = 72% 60% expo, elev = 70% 45% expo, Rud = 80% 55% expo
    High: Ail = 100% 78% expo, elev = 90% 59% expo, Rud = 100% 60% expo
  • willwillwill718
    Welcome to the Squawk DFJETFLYER. Found them a while ago, but thanks for responding. Got many flights on this little beast now. Loads of fun for a little $.
    Originally posted by DFJETFLYER
    They have the throw rates listed on motion rc. Just look at the stinger and you will find them in the text area.
  • DFJETFLYER
    A great little jet. Members at our club began flying and racing them last year. A lot of bang for the buck. They were pretty zippy with the 5 blade fan they came with last year. They seemed to sell out as fast as MRC could get them in. I finally ordered mine last month and was pleasantly surprized to find out they now come stock with the 12 blade set-up:).
    I do have one question for those that are flying them...What are the recommended control throws, D/R, and expos? Nothing mentioned for starting points in the manual.
