Official FMS 1700mm F4U Corsair V2 Thread
    • 8205
    Motion RC is pleased to announce the release of the FMS 1700mm F4U Corsair V2. This is the official message thread to post photos, videos, flight reviews and any questions about this iconic aircraft.
  • Bob Byrnes
    • Nov 2014
    • 2
    Hello: I'm new to this forum and although I have many years in the hobby. I have a new smaller house which means I have no real workshop area. That means I'm an ARF guy now. I fooled around with 90 mm EDF's for a couple of years and am now considering the big foamie Corsair. There is information out there about failing motor mounts in these bigger warbirds. Has there been an upgrade to the planes to improve on this part of the design that appeared to be marginal at best. Our Canadian buck is in the dumpster right now, so, I might wait until I am visiting family in Florida to save on the shipping expense.
    Best Regards to all you R/C folks.
    Bob :)
    • Bob Byrnes
      • Nov 2014
      • 2
      RE: 1700 mm F4U
      Bob :)
      [hr]
      Just read the L-O-N-G thread over on RC Groups and there is an upgrade metal plate that is now to be included that is considered the fix for this problem. Good to know.
        • 7333
        RE: 1700 mm F4U
        Thanks for the info Bob and WELCOME to the forum!
        From one ex Canuck to another.
        I used to live in the Lower Mainland in BC, where are you?
          • 8205
          RE: 1700 mm F4U
          Yes there is an upgraded metal plate for any new releases from the factory. I've had my current one since last December and knock on wood, I've had no problems with the motor mount.
          • wpmay
            Hobby Squawk Pilot
            • Nov 2014
            • 56
            • Charleston SC
            RE: 1700 mm F4U
            Does your current stock include the new plate? If not, do you know when the new plate will be available as a replacement part?
            Bill M.
              • 8205
              RE: 1700 mm F4U
              Not sure on that. I'll check tomorrow for you...
                • 8205
                RE: 1700 mm F4U
                Yes, all our current inventory has the new motor mount
                • wpmay
                  Hobby Squawk Pilot
                  • Nov 2014
                  • 56
                  • Charleston SC
                  RE: 1700 mm F4U
                  Thanks for the update.
                  • Scott
                    • 4
                    RE: 1700 mm F4U
                    Bob :)
                    Hey Bob, looking for a 1700mm F4U Corsair, depending on where you are, there are a couple of avenues you can go. I bought one from KMP out of Thunder Bay, but had to wait over a month because this guy didn't have in stock, he ordered from Diamond Hobby(his warehouse), went to Hong Kong, then got sick...etc, etc..He doesn't carry any parts. Just seemed to have an excuse for everything I asked him. There's a hobby store in Edmonton, AB. Hobby Alley West, he has access to FMS from a Canadian importer, prices are reasonable too, he doesn't carry any parts either, but can get them. Guy's name is Wayne, he's there monday-friday. I ordered the FMS 1700mm P51 from him the other day, told him I wasn't in a rush for it but I figure I'll see it in a week. Oh, the Corsair I got from KMP had the new motor mount in it, but make sure you check the screws.....mine were loose.
                    Good luck.
                    • apmech1
                      Warbirds old and new
                      • 266
                      • CVG Airport, Kentucky
                      RE: 1700 mm F4U
                      I have had the 1700mm corsair for a year now. Of the 3 1700mm FMS offers, it is my favorite. That being said, i am weary of the motor board becaus i love this plane so much. When I originally bought the plane, i made sure those screws were tight. I was doing my "annual" and I just pulled mine apart to inspect it prior to the flying season. No discoloration of any kind to indicate a pending failure but the 4 long screws needed about a 1/4 turn. It all seems good though.
                        • 8205
                        RE: 1700 mm F4U
                        I've had my most recent 1700 Corsair (yes I have had more than one, don't judge, lol) since December 2013 and have had no issues at all with the motor board or otherwise. Many happy flights. That's not to discount those who haven't had such luck but I can only speak for my own experience with this bird.
                        • apmech1
                          • 266
                          RE: 1700 mm F4U
                          So, I ran into a problem.... I saw that mrc had the upgraded motor board (large metal bracket). I saw directions on how to install the new metal board over existing plastic firewall... So I ordered it and in true mrc fashion, i had it in 2 days. Well I removed the old motor mount ( the X shaped one).. i then went to remove the 4 long screws. 3 of them came out. One just spun. I finally got it out. But now only have 3 screws holding it in. If I tighten the 3 remaining screws it shifts the motor all squirrely. Any suggestions? My first thought is drill 4 holes in new motor mount to match the X shaped mount, then use those 4 screws with the outer 3 out of 4... Probably clear as Mud...
                          • Tom
                            Super Moderator
                            • Sep 2013
                            • 905
                            RE: 1700 mm F4U
                            apmech1, it sounds like the threads are stripped. I think the easiest thing to do is to use a screw which is very slightly larger in diameter. Ideally a self tapping screw. You could use a machine screw if you have a tap and die set so you can re-tap the threads for the larger diameter screw.
                            • Tom
                              Super Moderator
                              • Sep 2013
                              • 905
                              RE: 1700 mm F4U
                              I also want to mention our current inventory of 1700mm Corsair and 1700mm P-47 have the new upgraded firewalls (motor board) AND motor mount. There were not any issues with the 1700mm P-51D so the FMS factory has not done any upgrade to that plane.
                              Interestingly, the issue was never really the motor mount or firewall. The issue was a poor quality glue used to mount the magnets into the motor. In 3 cases ALL the magnets came loose on a 1700mm Corsair which caused massive wobble in the motor and thus caused the firewall to crack and the mount to fail. Again, there were only 3 cases which is a tiny percentage. This happened in early August. While we were diagnosing the problem, FMS upgraded the motor mount and firewall. When we told them the issue was actually the magnets coming loose in the motor, they traced the problem back to a new brand of glue used in the motor factory. They immediately changed brands of glue. We sold this plane for 2 years without issue so anyone with the old mount and firewall is likely safe. If you want to upgrade the mount, we have directions in the support tab for the new mount showing how to do this.
                              • apmech1
                                • 266
                                RE: 1700 mm F4U
                                Thanks for the reply. I figured it out. In the back of the motor mount there are white inserts with threaded medal inside of them. During the unscrewing process the white inserts got pushed out of the back of the mount. All i needed to do was slowly thread the longer screw in (with out the motor mount) to get it to engage the treads of the whit inserts. Then pull on the screws to re-seat the white inserts. Once that was done i removed the screws and installed the motor mount. Everything is snug. Note: i noticed if you torque down the upper mount to board (long) screws (this applies to older motor board only) too much it will cause the new mount to bend and cause your motor to sit with a positive down thrust. I backed out the top 2 screws 1/2 to 3/4 of a turn and they are still tight and no more up thrust. The only other solution is to put stand offs behind the upper 2 mount to board screws. Or replace the motor board with the new style..
                                • Tom
                                  Super Moderator
                                  • Sep 2013
                                  • 905
                                  RE: 1700 mm F4U
                                  Thanks for the update. I like the idea of using standoffs though FMS says it is ok without. Of course the ideal is to use the new motor board BUT that requires cutting the fuse in half along the seam and gluing it back together (not fun)
                                  • apmech1
                                    • 266
                                    RE: 1700 mm F4U
                                    I just got done testing the power system of my corsair. It is showing 5873 RPM. 78.4 Amps. 1741 Watts. Just over 13lbs of static thrust (measured with fishing scale).Plane weighs in @ 13lbs 4.5 ozs. Stock motor, stock Esc (with default settings) stock unmodified prop. Battery 6s 5000mah 30-40C turnigy. All in all pretty happy with these numbers. I used a watt-meter and compared those numbers with my e-fuel gauge telemetry and they were spot on with each other. I love the Futaba telemetry logging. I'm a data and numbers guy.
                                    • Flygirl
                                      • 969
                                      • Glen Burnie, Maryland USA
                                      RE: 1700 mm F4U
                                      It shows! LOL!!  :D
                                      Lauren
                                        • 8205
                                        Anyone still enjoying the heck out of this model? Loved scaling mine out...
