For the record, here is my email transcript from Phoenix models
Dear Todd,
Thank you for the email. Yes, please use our suggestion for electric set up as showing from the manual ( as the same you show us below). We flown this model with that set up
Best regards,
Robert
> Hello
> I have the A26 INVADER GP/EP Size .46-.55 Scale 1:9 ¼ ARF on pre-order via Tower Hobbies. My plan is to outfit the plane using an electric setup. However in reviewing the recommended specs below I am concerned that the plane will be under-powered. If I use eCalc to review the suggested power setup it shows the plane being under powered.
> Can you confirm the plane has been tested with an electric setup?
> Can you confirm that the plane will indeed fly with the recommended electric setup?
> Do you have any sample videos of the plane flying with the electric setup?
> Todd
> RECOMMENDED MOTOR AND BATTERY SET UP
> - Motor: 2 X RIMFIRE .32 (not included)
> - Lipo cell: 2 X 4 cells / 4500 – 5500mAh (not included)
> - Esc: 2 X 45A (not included)
Dear Todd,
Best regards,
Robert
> Hello
> Todd
