    Click image for larger version  Name:	mastera.jpg Views:	63 Size:	63.1 KB ID:	247934
    The OV-10 Bronco is an American twin-turboprop light attack and observation aircraft that was developed in the 1960s. Purpose-built for Forward Air Control and intended to fly off unimproved short fields with its high lift narrow wingspan wings, the Bronco excelled in observation, target marking, ground attack, and troop deployment roles. In recent times, Broncos continue service as firefighting aircraft and flying specialized evaluation missions against ISIS, and in 2020 is set to serve as a US Air Force JTAC training aircraft.
    FlightLine by Motion RC delivers the historic OV-10 Bronco as an easy-to-transport, easy-to-fly, and easy-to-land RC model with pre-upgraded lights and metal suspension landing gear at a superb pricepoint. Presented in 1/8.5 scale and standing taller than other FlightLine twins like the 1/10 scale 1600mm P-38, the OV-10's twin boom and high elevator configuration displaces more volume during transport, so we designed the outer wing panels to unscrew for convenient transport standing on the model's retractable landing gear. DayBright LEDs, a large cockpit, tasteful detailing, and removable ordnance underscore a model that looks as great as it performs, while still being Beginner-Friendly and geared toward Every Day fliers.
    Armed to the Teeth
    Four plastic machine guns, four removable rocket pods, and a magnetic centerline tank comprise the Bronco's menacing ordnance package.
    Large Battery Bay
    The battery bay in the Bronco has ample space for your batteries and peripheral equipment including a gyro or gyroceiver. Achieve 5-8 minutes of flight time with two economical 4s batteries.
    Four Panel Flaps
    Wide four panel flaps enhance the FlightLine Bronco's STOL (Short Take Off and Landing) capability. Ideal for new warbird pilots looking for their first Big Twin, the Bronco assembles with only screws and is backed by a full line of easy-to-replace spare parts.
    FPV-Friendly Cockpit
    As an observer platform, the OV-10 is especially suited to visibility. Remove the two included pilots and install your own FPV camera equipment for the ultimate scale warbird FPV experience!
    Grass Friendly
    Designed for practical every-day RC use, tall pre-upgraded aluminum suspension struts and adequate ground clearance give the FlightLine Bronco the best off-road capabilities of any FlightLine aircraft. The large nose wheel and trailing-link main struts are especially suited for operating off of the toughest RC airfields, intended to fully compress without damaging the fuselage or props. Due to practical size constraints, the largest main wheel is used that can still fit in the reinforced foam boom without hydraulic compression assistance.
    LED Lighting
    The onboard MFCB powers five pre-installed LED lights, with ports for additional LEDs added by you. The model features two red/green wingtip static LEDs, one white dorsal LED, a flashing red ventral LED (shown), and one white landing LED in the nose that illuminates whenever the landing gear is extended.
    Magnetic Centerline Tank
    Flying with or without the removable ordnance, from any angle the FlightLine OV-10 Bronco has style in spades!
    Efficient Power System
    Our proven three blade 4s brushless outrunner power system provides power for all scale maneuvers including loops and rolls for 5-8 minutes based on throttle usage and flight conditions. Molded plastic parts throughout the model resist dents and dings during transport. 85% scale size props prevent tip damage during hard landings even when the landing gear is fully compressed.
    Removable Ordnance
    Remove the ordnance in seconds for easier storage or transport, or for clearing higher grass RC airfields. At 1/8.5 scale, the foam FlightLine OV-10 PNP is an excellent size for additional customization and everyday transport, as an alternative to the larger 1/6.5 scale balsa wood OV-10 ARF from Black Horse Models also available here at Motion RC. Both are excellent!
    Short Takeoff
    The FlightLine Bronco excels at short-field takeoffs, and is capable of steep angle landings with flaps down and power on. Generous rudder authority helps train new pilots to fly with rudder to keep the Bronco tracking on target throughout its very wide flight envelope!
    Easy To Transport
    The OV-10's outer wings are easily removable for convenient transporting to and from the flying field. This design allows the aircraft to stand on its three landing gear without its outer wings.
    Easy To Land
    The Bronco's four flap configuration and tricycle landing gear makes for an easy to land platform. A high mounted elevator provides excellent control authority in all conditions.
    FEATURES:
    • Easy-To-Transport with Removable Outer Wing Panels
    • Easy-To-Assemble with no glue required for main components
    • Easy-To-Program with pre-wired MFCB for dual motors/rudders and four flaps
    • Easy-To-Takeoff with four-panel flaps and high clearance, high power brushless motors
    • Easy-To-Fly with large size and low wing loading
    • Easy-To-Land with flaps, tall wheels, and trailing link aluminum suspension landing gear struts
    • Easy-To-Own with pre-upgraded suspension landing gear, pre-installed DayBright LED Lights, and readily available spare parts
    To better help everyone with wiring their OV-10 Bronco - Follow these instructions and watch the video:
    PDF instructions attached below
  • Tank guy
    Inertia rc
    • 67
    • Hampshire uk
    I need this eu stock date??
      Individual videos will come next week (this video has all three just in one place). I have included timestamp chapters in the YouTube description and the top pinned comment on the video so you can quickly navigate to the parts you want to see
      • dkalwishky
        Warbird Lover
        • Sep 2015
        • 1382
        • Des Moines, IA
        SWEET!
          Reserved 2
          • Tank guy
            Inertia rc
            • 67
            • Hampshire uk
            Any idea of cost
            • JohnVH
              • Nov 2017
              • 259
              • Lynden, WA
              Awesome!
              • dkalwishky
                Warbird Lover
                • Sep 2015
                • 1382
                • Des Moines, IA
                I just ordered mine!
                • Tank guy
                  Inertia rc
                  • 67
                  • Hampshire uk
                  You guys are legends I've wanted a foamy one for ages thank you never disappoint
                  • JLambCWU
                    • 267
                    Been waiting for this for so long!! Can’t wait to see everyone’s repaints! Especially the Marine Camo and Fire Fighting ones!
                    Congrats Alpha and the Freewing team!
                      • 8215
                      There ya go OV10!
                      • xplaneguy
                        Clear Skies and Contrails
                        • 558
                        • Edwards AFB/Rosamond, CA
                        Oh yeah! Love it!
                        • Tank guy
                          Inertia rc
                          • 67
                          • Hampshire uk
                          I cant afford the preorder yet have to wait till the end of the month
                          • DadsRcHangar
                            RC Pilot
                            • Feb 2020
                            • 26
                            • United Kingdom
                            Love it, when will the Euro site show for Pre-Buy?
                            want it need it, no idea we’re I going to put it 🤣
                            Chris
                            DRCH
                              • 8215
                              Chris
                              DRCH
                              The pre-order is live on EU site...
                              • JohnVH
                                • Nov 2017
                                • 259
                                • Lynden, WA
                                Where, I dont see it on the website?
                                  https://www.motionrc.com/collections...nco-1400mm-pnp
                                  • RCGuy83
                                    • Jan 2019
                                    • 126
                                      • 5397
                                      Sounds good to me
                                      • DadsRcHangar
                                        RC Pilot
                                        • Feb 2020
                                        • 26
                                        • United Kingdom
                                        not showing yet for me. Will keep refreshing.
