USS Nimitz CVN-68 1/200 Scale 1700mm (67") USA Aircraft Carrier - RTR
Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in high scale RC Warships, Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or sailing on calm lakes or pools, Bancroft vessels are made of high-quality materials including ABS, fiberglass, real wood, and photo-etched brass and steel parts.
USS Nimitz (CVN-68) is a US Navy supercarrier and one of the most recognizable vessels to ever sail the world's oceans. Originally commissioned as CVAN-68, "aircraft carrier, attack, nuclear powered", then redesignated as CVN-68, "aircraft carrier, multi-mission, nuclear-powered" on 30 June 1975, the USS Nimitz continues her storied service career in 2020.
Bancroft’s Elite Series of warships presents the 1/200 scale Aircraft Carrier USS Nimitz! Display this museum piece on your mantle or astonish your RC boat club with this functional RTR (Ready to Run) RC aircraft carrier. Over 300 total parts and 100 man-hours of work is already completed for you. Delivered Ready to Run (RTR), the vessel can be sailing within minutes of arrival, using the included 2.4Ghz radio transmitter, 2s Li-Ion battery, and charger. Only four AA batteries, ballast and minimal assembly is required. Set sail in minutes!
Pin-Sharp Details Over 100 hours of handcrafted details are completed at the factory using hundreds of fingernail sized brass Photo-Etched (PE) parts and larger molded sub-assemblies. The spacious hull and superstructure are ideal bases for additional customization, weathering, and LED lighting. |
| Active Flight Deck Position numerous included aircraft around the flight deck, including 1/200 scale F-18 Hornets, A-6 Intruders, E-2 Hawkeyes, S-3 Vikings, and SH-3 Sea King helicopers. Each aircraft arrives painted in base gray with basic insignia, and can be customized to represent your preferred squadrons during the Nimitz's many tours of duty. |
Exceptional Scale Realism Weighing nearly 30 pounds and stretching over 5.5 feet long, the Bancroft 1/200 scale Nimitz becomes the instant centerpiece of any military RTR RC maritime collection. Transport is not *that* difficult, but it will need to be lengthwise in a four door vehicle. In a sedan, you'll need to fold down the rear seat, and also ensure you have the following cavity available to fit the complete model: 1700mm length 425mm beam (width) 365mm height |
| Loaded with Accessories The Nimitz includes over one dozen 1/200 scale vehicles and equipment to support flight operations. I don't think 1/200 RC is possible, but I'm certain an intrepid modeler could configure a magnetized sub-floor mounted track under the hull, that could simulate moving vehicles by pulling the topside vehicle around. |
Four Motor Drive System Four pre-installed motor drive systems with steel drive shafts and three-bladed propellers propel the Bancroft Nimitz. All drive shafts and both rudders are waterproofed for your convenience. Without bow thrusters, the 1/200 Nimitz prefers to be turned while underway. Or a 1/200 tugboat fleet... |
| 1/200 Scale Battle Group! Sail the Bancroft 1/200 scale Nimitz aircraft carrier alongside similarly scaled vessels including the Bancroft 1/200 scale Missouri battleship. |
- RTR (Ready to Run) with 2.4Ghz radio, receiver, battery, and charger
- 2.4Ghz radio system and all electronics Pre-Installed
- Fully Painted and Detailed
- Zero assembly required --Get underway in minutes!
- Durable fiberglass one-piece molded hull and deck
- Hundreds of brass photo-etched (PE) parts and high detail parts
- Extensively detailed and hand finished
- Hyperscale detail comprising over 100 hours of hand craftsmanship
- Four motors with steel drive shafts and counter-rotating propeller pairs
- Quick-Detach Superstructure for easy access to the ship's interior
- Pre-Installed Rigging with simple disconnect design
- Rated for calm ponds, pools, and lakes appropriate for RC Boats
- Bancroft USS Nimitz 1/200 Scale 1700mm (67") USA Aircraft Carrier - RTR
- 2.4Ghz Radio and Receiver, pre-installed
- Four motor drive system, pre-installed, with XT60 battery connector
- Steering servo, pre-installed
- 2s 7.4V 2800mAh Battery with XT60 connector
- 2s Battery Charger
- Basic Tabletop Display Stand
- Four (4) AA-sized 1.5V dry cell batteries, Alkaline or NiMH
