Chris Craft 19' Racing Runabout
  • Chris Craft 19' Racing Runabout
    Hi
    I have started to build my Chris Craft today.
    Begiining with the frames......
    but honestly: for this price. i have never seen such a bad "laser cut" wooden parts as this here. Nothing is complete, you always have to cut on the backsinde with a knife and lots of sandpaper work to get them smooth.
    And the quality of the wood for the frames is very low
    I hope it will get better later with the mahagoni......
    Anyone interested in a build log? Then I will post my steps.......
    Tyrell63 I am always interesting in seeing other modelers' build logs. Especially for as intensive a build as yours sounds like it will be!
      Originally posted by Tyrell63 View Post
      Hi
      T6, Please post your build. Could you also post a picture of which Chris Craft you are building? Is it Dumas Kit #1249? Best, LB
        Building Log
        Chris Craft
        Dumas Kit No 1249
        Click image for larger version  Name:	IMG_1606.jpg Views:	0 Size:	117.2 KB ID:	320869Click image for larger version  Name:	IMG_1626.jpg Views:	0 Size:	115.1 KB ID:	320868Click image for larger version  Name:	IMG_1627.jpg Views:	0 Size:	132.9 KB ID:	320863Click image for larger version  Name:	IMG_1628.jpg Views:	0 Size:	101.0 KB ID:	320862
        The manual comes in 2 "books"
        Click image for larger version  Name:	IMG_1629.jpg Views:	0 Size:	83.9 KB ID:	320861Click image for larger version  Name:	IMG_1630.jpg Views:	0 Size:	138.3 KB ID:	320864
        and a full size plan
        Click image for larger version  Name:	IMG_1631.jpg Views:	0 Size:	126.4 KB ID:	320872
        1st Problem ....it is all in inch, not in cm
        So you have to drill a hole in 1/4" (I will drill in 6mm instead)
        all the frames and the keel (2 parts)
        Click image for larger version  Name:	IMG_1608.jpg Views:	0 Size:	133.2 KB ID:	320866Click image for larger version  Name:	IMG_1625.jpg Views:	0 Size:	140.6 KB ID:	320865Click image for larger version  Name:	IMG_1612.jpg Views:	0 Size:	163.6 KB ID:	320867
        and the deck frame
        Click image for larger version  Name:	IMG_1613.jpg Views:	0 Size:	34.5 KB ID:	320870
        All these parts need a lot of sanding. The quality of these cuts are very low.
        (Will be continued soon.....after my S.E.5a is covered)
          [QUOTE=Tyrell63;n320860]Building Log: Chris Craft Dumas Kit No 1249 /QUOTE]
          T6, Thank you. I have begun the same kit, though some 15+ years ago. I am at the stage of applying the mahogany strips and could not decide which gluing method to use. I did not give up on the project, just set it aside in my last relocation. Your build might inspire me to "begin again". It is a beautiful design and there are a few minor challenges so far. Looking forward to watching your progress. Best, LB
            Building the Hull (Part 1)
ID:	321579Click image for larger version
ID:	321573Click image for larger version
ID:	321572Click image for larger version
ID:	321574Click image for larger version
ID:	321577Click image for larger version
              Building the Chine
ID:	322789Click image for larger version
ID:	322790Click image for larger version
ID:	322791Click image for larger version
ID:	322793Click image for larger version
                Planking the Bottom
                Question: Which glue I can use? In the manual they said:
                No expoxy....
                Gap filling (medium) CA glue. The bottom plank are made of PVC
                Any suggestions?
                  Planking the Bottom Question: Which glue I can use? In the manual they said: No epoxy....Gap filling (medium) CA glue. The bottom plank are made of PVC. Any suggestions?
                  T6, If you're using CA+ (gap filler), rough up the PVC planks a bit for better adhesion. I used CA+ and accelerator to plank mine, making certain I wiped away as much CA+ as I could before applying the accelerator. Note that my kit has plywood planks not PVC and I epoxy-coated the interior of the boat after this step. Best, LB
                    T6?
                    Do you have a link? Or company .. so I can search for
                      Elbee commented
                      Editing a comment
                      T6 is my shorthand for your username.
                  • #11
                    T6?
                    MotionRC Adhesives. https://www.motionrc.com/collections/ca-glue
                    T6, My guess is you can find CA adhesives in Singapore at any hobby center or even a hardware store. Best, LB
