BTW you got a coupon or QR code to get you free castle link connector.. Check your packaging or your box it came in.
Anyone Into Unlimited Hydros?
All I know is that it's brass 3-blade. Given to me by that prop guy you mentioned.
https://www.youtube.com/@toddbredaComment
Hangar: EDF's: Mig 29 TV "Cobra", A-10 Arctic, SU-27 90mm 8S:F22 Red Lion/EuroFighterBronzeTiger/F18 Canadian & Tiger Meet/F16/F4 Jolly Rodgers & Blue Angel, 80&90 TV Avanti, Viper, Stinger 90. Props: 1600 Corsair & Spitfire, B-24, 1700 P-51, 60" Beast & P2 Bipe, Extreme Flight-FW-190 Red Tulip, Slick 60, 62" Extra 300, 62" MXS Heavy Metal, 62" Edge😀 1Comment
BTW the ABC props are Beryllium copper so dont mistake it for brass because dry grinding on them without PPE is very hazardous . You can also age them to be very hard. High power FE torque can snap props. That's why many run Stainless steel. Ive contacted Brian but Ive misplace my saw props. Hopefully in a few months I can show you some of my scales running. I've been really buzy trying to get the shop together and taking care of real life. But plan to get the props to him sooner than later.
Is the site under reconstruction seems alot has change.
Nice RTR have fun with it.
Hubert👍 1Comment
Good tip on the beryllium copper props, I had no idea dry grinding them was that hazardous. Hope the shop comes together soon, those wood scratch built 1/8 scale hydros would be great to see running.Comment
I also have an ABC speed worksheet for the props but the site is not letting me post an excel extension 😕Comment
"All these propellers have been hardened after annealing to allow pitching. Anneal C-20 beryllium copper by heating to 1450 deg. F (dull red) in a dark room. Quench immediately in ice cold water. If the props are heated to hot during annealing, the beryllium will leach out & the blades connot be hardened. I re-anneal finished balanced pitched props to ensure stabilization before hardening.
C-20 beryllium copper (copper alloy C82500) blades are hardened in a heat treating oven. Props are held at 650 deg. F (+- 5 deg F) for 2.5 to 3 hrs. The time in the oven is not critical, but the temperature is to achieve the ultimate tensile & yield strength. The tensile strength should be 160,000 psi with a rockwell hardness of 45. These blades will not bend & cannot be repitched without annealing."
~All photos and information are the contributions of the late James Allen~
A dearly missed friend in RC boating.
HubertComment
"This magnetic prop balancer can be leveled with three set screws accessible from the top of the balancer. A hardened precision ground CONCENTRIC shaft makes this device very sensitive. Once the blades are balanced, very slight polishing with 800 grit paper throws the balance off! Notice the round leveling device under the propeller. IF A PROPELLER BLADE ALWAYS BALANCES IN THE SAME HORIZONTAL POSITION, IT IS OUT OF BALANCE! EVERYTHING BELOW THE CENTER LINE NEEDS TO HAVE ITS WEIGHT REDUCED! THIS COULD BE THE LEADING EDGE OF ONE BLADE & THE TRAILING EDGE OF THE OPPOSITE BLADE FOR TWO BLADED PROPELLERS! THE SAME PRINCIPLE APPLIES TO MULTI BLADED PROPS."
~James Allen~
The pitching blocks use dowel pins for alignment. When the pitching blocks are closed in a vise, the propeller blades are held securely for pitching up or down. On the left are pitching blocks used to bend 2170 blades; in the middle V-967 blades; on the right are pitching block cavities.Comment
The material used in the pitching blocks is West System 105 epoxy resin; 205 fast hardener; & a very large amount of 404 high density filler. The blades are covered with a thin film of grease to prevent the epoxy from sticking. Do one side at a time; then use a thin film of grease to prevent the second side from sticking.Comment
