Sportsail Sailboat from Bancroft - RTR
Smooth Sailing!
Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in high scale RC Warships, Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or sailing on calm lakes or pools, Bancroft vessels are made of high-quality materials including ABS, fiberglass, real wood, and photo-etched brass and steel parts.
The Sportsail Sailboat is a leisure RTR boat you can take with you to any calm pond, lake or other calm body of water.
Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Sportsail can be operating within minutes of arrival, using the included 2.4Ghz radio transmitter and eight AA batteries. Only eight AA batteries and minimal assembly is required.
Fully Adjustable Just as on a larger sailboat, the Bancroft Sportsail's fittings are adjustable. The boom vang can be raised and lowered via a threaded fitting, and the jib boom and sail positions can be adjusted by tensioning the included rigging. |
| Functional Rudder A deep rudder provides positive control even when at extreme heeling angles. |
Race-Ready With a standardized hull length and weight, the Sportsail is ideal for club racing. |
| Improved Scale Deck An All-New deck has been designed to evoke a more scale silhouette of full-size sailing yachts. |
Adjustable Sails Refine the Sportsail's setup to suit your preferences for racing or cruising! |
| Molded Hull Durable molded hull withstands the choppy water typical on race day, while maintaining easy, stable handling on flat water as well. |
RTR - Ready To Run Fully painted with all rigging and sails included and all onboard electronics pre-installed, the Bancroft Sportsail requires only AA batteries for the radio and receiver pack! |
| Easy To Transport Perfectly sized for everyday sailing, the Bancroft Sportsail is an ideal first sailboat for beginners to learn rigging, maintenance, and handling. The Sportsail is also a globally recognized race-class sailboat! It is quite literally Two In One! |
- RTR (Ready to Run) with 2.4Ghz radio, receiver, battery, and charger
- All Electronics are pre-installed
- Fully Painted
- 2.4Ghz radio system and all electronics Pre-Installed
- Rated for calm ponds, pools, and lakes appropriate for RC Boats
- Bancroft Sportsail Sailboat - RTR
- 2.4Ghz Radio and Receiver, pre-installed
- Steering servo, pre-installed
- 8x AA batteries
- Eight (8) AA-sized 1.5V dry cell batteries, Alkaline or NiMH
