Building a 3D printed RC submarine. The French Redoutable.
    • 4836
    RCjetdude, First I've seen this thread of your submarine build. You are just taken it out there and beyond. What a great project, incredible work, Sir. Best, LB
      Surprise!!
        Turns out the pitch controller does not play well with a PCM receiver. Works perfectly with the PPM receiver I ordered. Now to send it off for re-tuning at Radio South. At least I can move forward with this build.
        • Peterboi
          Rc Stinger
          • Aug 2019
          • 16
          • NEW ZEALAND
          It be interesting too see your maiden
            I will get video. I tried to trim it in my bathtub but the dang thing is too long...or my tub is too short. Moving forward with opening my pool a little early as a result and may pick up a small kiddie pool in the meantime. I am anxious to get it trimmed so all I have to do is drop the receiver back in it when I get it back.
              Picked up a cheap inflatable kiddie pool and have been working on trimming it. You have to establish both a waterline trim and static dive trim so it is quite the process of trial and error. It is a matter of where to place weight in the keel and how much and then where to place foam above and below the waterline. When done it should sit in the water at the waterline and then when the ballast tank is flooded, it should submerge straight down and the deck should wash over evenly. It is easier said than done.
                • 4836
                RCjetdude, It doesn't sound easy at all.:sweat:. Your sub does look very good just sitting there, don't you think? Proud papa. Best, LB
                  I finally got to start playing with the Redoutable in the big pool with all RC gear in operation. It still needs some work but initial tests look good. I got this video of it performing a static submerge and surface. Pretty cool stuff.
                    And here is its first lake run.
                      • 4836
                      RCJD, Grade "A" on Sea Trials, Sir. Bravo Zulu on the entire project. I call that a reward unto itself. Best, LB
                        It was good to finally get it out into open water and see just how it would behave under power. I trimmed it to be just slightly positively bouyant when the ballast tank is flooded. Basically everything submerges except for the periscope. That way the dive planes will pull it down under forward motion and if it ever quit should return to the surface without even having to blow the ballast tank.
                        • Marco Polo
                          Go NAVY
                          • Aug 2012
                          • 609
                          • Illinois
                          RCjetdude Super awesome build and videos, I hope to see other members venturing into submersibles. Who knows, maybe a Bancroft sub(s) will grace the product pages of Motion RC in the not too distant future...
                            Thank you sir. They are fascinating. Now in addition to this one and my 1/35th Nautilus, I also have a fiberglass Typhoon hull and I am building an Ohio'ish class sub based on a piece of 6" PVC pipe. It will be almost 7-1/2 feet long. I am designing and 3D printing the nose, tail and deck and will likely mold the sail and stern control surfaces for it. The main thing with it is the modularity permitted by using the PVC pipe for the hull. The nose and tail will be removable to access a slide in tray that contains all the running gear.
                            • mr.frankenjet
                              Eat, sleep, FLY FLY FLY !
                              • 448
                              • Virginia, USA
                              very cool, NICE work !!
                              rc flyin addict
