Official Kyosho 1/27 Scale Mini-Z Subaru Impreza WRC 2008 Readyset AWD Car - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Mini-Z Subaru Impreza WRC 2008 Readyset 1/27 Scale AWD Car - RTR from Kyosho - KYO32614WR
    To bring its dynamic performance to even more drivers, the MINI-Z AWD is now available in a Readyset. The MA-020 chassis features VCS (variable camber suspension) on the front that optimizes camber change with suspension stroke and a specially designed circuit board. The chassis design allows space for installing the optional MZW431 gyro unit. The gyro can be adjusted by turning a small volume adjuster on the chassis to reflect the amount of steering correction in response to changes in chassis posture, allowing beginners through to experts to drive to their full potential.
    Fully kitted out with precision ball bearings, the high drive efficiency of the MA-020 chassis is complimented in the Readyset by the unique scale body and 2.4GHz Syncro KT-531P R/C system that requires no frequency band setting; all at a great value price. Simply install the batteries to enjoy the thrill of drift driving with the included set of drift tires. The chassis is compatible with nearly all ASC MINI-Z bodies (additional parts may be required for some body styles). The MINI-Z AWD promises a unique world of dramatic racing action for you to experience and enjoy and your Kyosho car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    VCS Front Suspension
    Features VCS front suspension that optimizes camber change with suspension stroke. Replacement of front suspension coil springs is easy with no tools required.
    Gyro Mounting Space*
    AWD version is designed with special mounting space for gyro (MZW431/sold separately*) and gyro adjustment volume control.
    Strut-Type Rear Suspension
    Equipped with strut-type rear suspension.
    Drift Tires
    Equipped with drift tires and Full 14 ball bearing set as standard.
    FEATURES:
    • MINI-Z AWD Readyset based on MA-020 chassis
    • Special circuit board updated with optimized steering control program
    • Chassis features gyro sensitivity adjustment function
    • Drift tires are installed as standard
    • Readyset requires only batteries to be ready for action!
    • Features 2.4GHz Syncro KT-531P transmitter that requires no setup of frequency bands
    • Factory completed body comes with display model quality finish
    • Features VCS (variable camber suspension) that adjusts camber in accordance with suspension stroke
    • Coil spring on front suspension can be easily replaced without tools
    INCLUDES:
    • Kyosho Mini-Z Subaru Impreza WRC 2008 Readyset 1/27 Scale AWD Car - RTR
    REQUIRES:
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 11 AND UP
    SKILL LEVEL : BEGINNER
    BUILD TIME : NONE
    Model Scale 1/27
    Length 161mm / 6.3in
    Width 72mm / 2.8in
    Height 52mm / 2.0in
    Weight (No Battery) N/A
    Wheelbase 94mm / 3.7in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis AWD (MA-020)
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 7.23, 6.38, 6.0, 5.71, 5.34, 4.97, 4.5:1
    Final Drive Ratio N/A
    Pinion 15T, 17T, 19T, 21T
    Spur Gear N/A
    Differential N/A
    Ball Bearings 14
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Servos N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
