Official XK Innovations 1/18 Scale Vortex High Speed 4WD Buggy - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Vortex High Speed 1/18 Scale 4WD Buggy - Blue - RTR from XK Innovations - WLT-A959-BLUE
    Vortex High Speed 1/18 Scale 4WD Buggy - Red - RTR from XK Innovations - WLT-A959-RED
    Version Info: Includes a 2S 7.4V 1100mAh LiPo battery with a 390 motor capable of speeds up to 25mph.
    The XK Innovations Vortex High Speed Buggy is a 1/18 scale buggy that arrives to your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Adjustable Suspension
    Fully independent front and rear suspension work to absorb punishment while keeping your wheels on the ground as much as possible. Adjust the suspension at various points to tune its performance to your preference!
    Easy To Maintain
    Thrilling performance is matched with an aggressive buggy racer configuration and iconic body style. The shell is quickly removable to access internal electronics
    Four Wheel Drive
    Accelerate with maximum traction using active four wheel drive!
    Durable Design
    The tough body materials can absorb a lot of punishment.
    Upgradeable
    Perfect out of the box for most drivers, this buggy is also easy to tinker with, upgrade, or customize for creative gearheads looking for an affordable base vehicle.
    Ready To Run (RTR)
    Everything is included in the box to get you on the road in minutes, just add AA batteries for the radio transmitter! A 2.4Ghz radio transmitter, 2s 7.4v Li-Ion battery, and convenient battery charger are included.
    FEATURES:
    • Functions: forward, backward, turn left, turn right, direction trimming
    • Big wheels and high chassis provide good climbing performance
    • Has no problem going through the dirt, grass, and gravel
    • 2.4GHz technology with four-wheel-drive system to provide plenty of power
    • 4 wheel drive to ensure a stable and smooth driving experience
    INCLUDES:
    • XK Innovations Vortex High Speed 1/18 Scale 4WD Buggy (Blue) - RTR
    • 2.4GHz Transmitter and charger
    • 2s 7.4V 1100mAh Li-Po battery w/ JST connector
    REQUIRES:
    • Four (4) AA size batteries for the radio transmitter
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : NONE
    Model Scale 1/18
    Length 245mm / 9.6in
    Width 175mm / 6.8in
    Height 94mm / 3.7in
    Weight (No Battery) 1700g / 59.96oz
    Wheelbase 165mm
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Size (Diameter x Width) 61mmx28mm
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-Filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor Brushed 390 Motor
    Battery 2S 7.2V 1100mAh LiPo battery with JST connector
    Servos 17g
    Radio N/A
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Intermediate
    Assembly Time 1+ Hours
    Recommended Environment Offroad
