Fierce 1/12 Scale 4WD Buggy - RTR from XK Innovations - WLT-124019-001
The XK Innovations 124019 Fierce is a 1/12 scale 4WD Buggy high-performance buggy design that is fully off-road capable and delivers top speeds in excess of 35 MPH! In addition to a durable aluminum chassis and convenient access to electronics, the independent suspension with aluminum, coil-over shocks are perfect for high-speed runs on the flats or aggressive performance in gnarly desert terrain. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
Features:
AGE LEVEL : 12 Years and Up
SKILL LEVEL : Beginner
BUILD TIME : None
Feature-Packed The feature list is extensive for a buggy at this price point! From the aluminum main chassis and shock towers, 550 brushed motor, reliable ESC, and high-grip rubber tires, this buggy will exceed your expectations. |
Reliable 2.4GHz Radio System Unlike lesser models, this vehicle comes standard with an interference-free “pro-style” 2.4GHz radio system that offers extended range and comfortable control. Simply add 4 AA alkaline batteries for the transmitter (not included) and you’re ready for supreme driving action! |
- Functions: Fully proportional forward, backward, turn left, turn right
- Interference-free 2.4GHz radio technology
- Tackles all terrain and conditions
- Aluminum, coil-over shock absorbers
- Aluminum alloy main chassis plate and shock towers for supreme durability
- Metal-geared differentials
- 4WD system provides plenty of power with impressive acceleration
- XK Fierce 1/12 Scale 4WD Buggy - RTR
- 2.4GHz Transmitter
- 2S 7.4V 2200mAh LiPo battery with T-connector
- USB-Powered LiPo Battery Charger
- Tools and Instructions
- Four (4) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (4 Pack)
BUILD TIME : None
| Model Scale | 1/12 |
| Length | 350mm / 13.6in |
| Width | 205mm / 8.0in |
| Height | 115mm / 4.5in |
| Weight (No Battery) | 1110g / 39.5oz |
| Wheelbase | 235mm / 9.1in |
| Ground Clearance | 30mm / 1.1in max |
| Body | Polycarbonate, factory painted and decorated |
| Chassis | Aluminum alloy |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | 134mm x 70mm |
| Wheel Hex Size | 14mm |
| Tire Tread | Multi-surface |
| Bushing Material | N/A |
| Suspension | 4-wheel independent |
| Shock Type | Oil-Filled, Coil-Over, Adjustable |
| Transmission | F/R Differentials, Center shaft |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | Metal Bevel Gear |
| Ball Bearings | Yes |
| Brakes | Electronic |
| Electronic Speed Control | 60A Brushed, splash-proof |
| Motor | 550 Brushed |
| Battery | 2S LiPo battery with T-connector (included) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | Splash-proof, 5-wire |
| Radio | 2 Channel (included) |
| Lights | No |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Beginner |
| Assembly Time | None |
