Official XK Innovations Fierce 1/12 Scale 4WD Buggy Thread
  • jbaartz
    • Sep 2020
    • 481
    Fierce 1/12 Scale 4WD Buggy - RTR from XK Innovations - WLT-124019-001
    The XK Innovations 124019 Fierce is a 1/12 scale 4WD Buggy high-performance buggy design that is fully off-road capable and delivers top speeds in excess of 35 MPH! In addition to a durable aluminum chassis and convenient access to electronics, the independent suspension with aluminum, coil-over shocks are perfect for high-speed runs on the flats or aggressive performance in gnarly desert terrain. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Feature-Packed
    The feature list is extensive for a buggy at this price point! From the aluminum main chassis and shock towers, 550 brushed motor, reliable ESC, and high-grip rubber tires, this buggy will exceed your expectations.
    Reliable 2.4GHz Radio System
    Unlike lesser models, this vehicle comes standard with an interference-free “pro-style” 2.4GHz radio system that offers extended range and comfortable control. Simply add 4 AA alkaline batteries for the transmitter (not included) and you’re ready for supreme driving action!
    Features:
    • Functions: Fully proportional forward, backward, turn left, turn right
    • Interference-free 2.4GHz radio technology
    • Tackles all terrain and conditions
    • Aluminum, coil-over shock absorbers
    • Aluminum alloy main chassis plate and shock towers for supreme durability
    • Metal-geared differentials
    • 4WD system provides plenty of power with impressive acceleration
    Includes:
    • XK Fierce 1/12 Scale 4WD Buggy - RTR
    • 2.4GHz Transmitter
    • 2S 7.4V 2200mAh LiPo battery with T-connector
    • USB-Powered LiPo Battery Charger
    • Tools and Instructions
    AGE LEVEL : 12 Years and Up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/12
    Length 350mm / 13.6in
    Width 205mm / 8.0in
    Height 115mm / 4.5in
    Weight (No Battery) 1110g / 39.5oz
    Wheelbase 235mm / 9.1in
    Ground Clearance 30mm / 1.1in max
    Body Polycarbonate, factory painted and decorated
    Chassis Aluminum alloy
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 134mm x 70mm
    Wheel Hex Size 14mm
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Oil-Filled, Coil-Over, Adjustable
    Transmission F/R Differentials, Center shaft
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Metal Bevel Gear
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control 60A Brushed, splash-proof
    Motor 550 Brushed
    Battery 2S LiPo battery with T-connector (included)
    Servos Splash-proof, 5-wire
    Radio 2 Channel (included)
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
  • Joel Scott
    • Dec 2022
    I assume this is the same as the WL Toys buggy?
    • jbaartz
      • Sep 2020
      • 481
      I believe both XK Innovations and WL Toys are subsidiaries/brands of Shantou Chenghai Weili Toys Co. Ltd and all XK products will have WL Toys written on the box; However, I don't believe that they have duplicate products between the brands.
      • Mikeacro
        • Aug 2020
        I don’t see any spare parts listed on motion’s website
        • finn6020
          • Mar 2023
          where can i find it? If i would like to purchse it ?
          best regards
          New in this
          Finn
          • Janus01
            • May 2023
            I would also like to know where this is purchasable?
            Best regards
            Janus
            Consultant at https://airfryermad.dk/
            • topgun1010
              • Feb 2024
              I would also like to know where this can be purchased?
              Best
              Karl
              Blogger: Swedeats
              • Battleship
                • Oct 2020
                • 241
                This is my 1/10 scale Bigfoot monster truck and is the. Closest I’ll ever get to wishing I owned the real Bigfoot monster truck big foot Ttyl for now
