Official Tamiya 1/10 Scale Frog 2WD Buggy (with ESC) KIT Thread
    Frog 1/10 Scale 2WD Buggy (with ESC) - KIT from Tamiya - TAM58354-A
    Version Info: This buggy is a KIT. Assembly and painting are required. Photos show a completed and painted model. Minimum 2 channel radio system, battery, charger, and steering servo will need to be purchased separately.
    The Iconic Tamiya Frog Returns!
    Originally introduced in 1983, the 2WD Tamiya Frog buggy created a huge splash with its unusual design and high performance. This model, along with others from various manufactures, are credited with starting the RC off-road craze in America. The Frog now makes a comeback, modernized where applicable, but with its basic architecture essentially intact. Maintaining use of its characteristic space frame, the shock absorbers for the trailing-arm rear suspension have been updated to a diaphragm-type, while rear dogbone-style driveshafts deliver reliable power transmission. The sleek polycarbonate body remains the same, while original 3-piece wheels feature front grooved and rear spike tires for excellent off-road performance. This specific kit version also includes a Hobbywing 1060 Brushed ESC for convenience and ease of operation.
    Packed with Innovation
    The Frog features an ABS space frame with nylon suspension components and bumper for a lightweight yet rugged chassis that is perfect for off road running. The battery compartment is located in an ultra-low position, giving the Frog the stability and balance needed to handle the roughest terrain and tallest jumps. Advanced 4-wheel independent suspension features a double wishbone-type front assembly featuring inboard springs and durable steel radius arms. Rear trailing arms contain horizontally mounted aluminum oil-filled dampers, while a sealed gearbox with differential ensures optimal cornering. Full gearbox ball bearings and three available gear ratio offers maximum efficiency regardless of terrain!
    Your Tamiya Frog is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    • Revised aluminum side dampers inspired by TRF shock design.
    • Dog-bone style drive train with original rubber boots.
    • Original 2WD buggy design featuring ABS resin frame, horizontally mounted oil dampers, and inboard spring-type front suspension.
    • Brushed 540 motor.
    • Ribbed racing front tires
    • High grip rear pin-spike tires
    • Original, realistic 3-piece wheels
    • Includes Hobbywing 1060 2S-3S Brushed ESC
    • Tamiya Frog 1/10 Scale 2WD Buggy (with ESC) - KIT
    • Instruction Manual
    AGE LEVEL :14 and up
    SKILL LEVEL :beginner
    BUILD TIME :3+ hours
    Model Scale 1/10
    Length 410mm / 16in
    Width 240mm / 9.4in
    Height 145mm / 5.7in
    Weight (No Battery) N/A
    Wheelbase N/A
    Ground Clearance 34mm / 1.3in
    Body Polycarbonate (clear)
    Chassis ABS resin
    Drivetrain 2WD
    Wheel Hex Size N/A
    Tire Tread Multi-surface
    Bushing Material Oilite bronze
    Suspension Solid axle rear, swing axle front
    Shock Type Spring dampers
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 16, 18, 19T
    Spur Gear 49, 50, 52T
    Differential Gear
    Ball Bearings Partial
    Brakes Electronic
    Electronic Speed Control Hobbywing 1060 brushed (included)
    Motor 540-Brushed
    Battery 7.2v NiMH or 7.4v 2S LiPo with Tamiya (molex) connector (required)
    Servos Standard size (required)
    Radio 2 Channel (required)
    Lights No
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time 3+ Hours
    • 4868
    So Very Cool...a blast from my past, that's for sure. I worked PT at a Hobby Shop for 8+ years in the '80's. We sold the entire Tamiya catalog, but when RC hit big, this was our # ONE seller. I raced the Tamiya onroad cars but still built many of these for display, sale, and customers. What a hoot, Aros. Great to see it hasn't changed much. Best, LB
