Official Kyosho Mini-Z White Nissan Skyline GT-R V.Spec R33 MA-020 1/27 Scale AWD Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    To bring its dynamic performance to even more drivers, the MINI-Z AWD is now available in a Readyset. The MA-020 chassis features VCS (variable camber suspension) on the front that optimizes camber change with suspension stroke and a specially designed circuit board. The chassis design allows space for MZW431 gyro unit. The gyro can be adjusted by turning a small volume adjuster on the chassis to reflect the amount of steering correction in response to changes in chassis posture, allowing beginners through to experts to drive to their full potential.
    Fully kitted out with precision ball bearings, the high drive efficiency of the MA-020 chassis is complimented in the Readyset by the unique scale body and 2.4GHz Syncro KT-531P R/C system that requires no frequency band setting; all at a great value price. Simply install the batteries to enjoy the thrill of drift driving with the included set of drift tires. The chassis is compatible with nearly all ASC MINI-Z bodies (additional parts may be required for some body styles). The MINI-Z AWD promises a unique world of dramatic racing action for you to experience and enjoy and your Kyosho car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    VCS Front Suspension
    Features VCS front suspension that optimizes camber change with suspension stroke. Replacement of front suspension coil springs is easy with no tools required.
    Gyro
    Equipped with a special mounting space and adjustment control for the gyro unit.
    Strut-Type Rear Suspension
    Equipped with strut-type rear suspension.
    Drift Tires
    Equipped with drift tires and Full 14 ball bearing set as standard.
    • MINI-Z AWD Readyset based on MA-020 chassis
    • Special circuit board updated with optimized steering control program
    • Chassis features gyro sensitivity adjustment function
    • Drift tires are installed as standard
    • Readyset requires only batteries to be ready for action!
    • Features 2.4GHz Syncro KT-531P transmitter that requires no setup of frequency bands
    • Factory completed body comes with display model quality finish
    • Features VCS (variable camber suspension) that adjusts camber in accordance with suspension stroke
    • Coil spring on front suspension can be easily replaced without tools
    • Wide range of optional parts are available to be installed
    • Factory assembled chassis with pre-installed R/C unit
    • Pre-painted factory assembled plastic body, finished with markings
    • 2.4GHz Syncro KT-531P transmitter
    • Mini pylon
    • Drift tires (installed)
    • Pinion gears (15T, 17T, 19T, 21T)
    • Spur gears (27T, 29T, 31T)
    • Pinion gear tool
    • Spare wheel nuts and wheel wrench
    AGE LEVEL : 11 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/27
    Length 165mm / 6.5in
    Width 70mm / 2.75in
    Height 46mm / 1.8in
    Weight (No Battery) 193g / 6.8oz
    Wheelbase 94mm / 3.7in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis MR-020
    Drivetrain AWD
    Wheel Hex Size N/A
    Tire Tread 59.5mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 7.23, 6.38, 5.71, 5.97, 5.34, 4.97, 4.5:1
    Final Drive Ratio N/A
    Pinion 15T, 17T, 19T, 21T
    Spur Gear 27T, 29T, 31T
    Differential N/A
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Servos N/A
    Lights Yes
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Smooth paved surfaces
  • gycaduz
    Banned
    • Sep 2023
    • 0
    Integrative reviews provide a holistic understanding of a topic by considering diverse perspectives and types of evidence. This comprehensive manage negative reviews​ approach contributes to a more nuanced and multifaceted interpretation of complex phenomena.​
    • gycaduz
      Banned
      • Sep 2023
      • 0
      The primary purpose of Secure Training Centers is to rehabilitate and educate young individuals who have committed offenses. Unlike traditional correctional facilities, STCs are designed to security services blog​ prioritize the rehabilitation of juvenile offenders.​
