Official Kyosho Mini-Z T Dodge Challenger SRT Hellcat Redeye 1/27 Scale AWD Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	kyosho-mini-z-torch-red-dodge-challenger-srt-hellcat-redeye-1-27-scale-awd-car-rtr-motion-rc-35133446455481.jpg Views:	0 Size:	78.7 KB ID:	397107
    Click image for larger version  Name:	kyosho-mini-z-plumb-crazy-purple-dodge-challenger-srt-hellcat-redeye-1-27-scale-awd-car-rtr-motion-rc-35133532307641.jpg Views:	0 Size:	75.2 KB ID:	397108
    To bring its dynamic performance to even more drivers, the MINI-Z AWD is now available in a Readyset. The MA-020 chassis features VCS (variable camber suspension) on the front that optimizes camber change with suspension stroke and a specially designed circuit board. The chassis design allows space for installing the optional gyro unit MZW446 (Sold separately). The gyro can be adjusted by turning a small volume dial on the chassis to reflect the amount of steering correction in response to changes in chassis posture, allowing beginners through to experts to drive to their full potential.
    Fully fitted out with precision ball bearings, the high drive efficiency of the MA-020 chassis is complimented in the Readyset by the unique scale body and 2.4GHz Syncro KT-531P R/C system that requires no frequency band setting; all at a great value price. Simply install the batteries to enjoy the thrill of drift driving with the included set of drift tires. The chassis is compatible with nearly all ASC MINI-Z bodies (additional parts maybe required for some body styles). The MINI-Z AWD promises a unique world of dramatic racing action for you to experience and enjoy and your Kyosho car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    A New Chassis
    Special AWD chassis is based on the MA-02 chassis and features the RA45 unit.
    KT-531P Transmitter
    Includes stylish Syncro KT-531P transmitter. Features steering / throttle trim as well as steering dual rate adjustment and LED control function.The transmitter also has a Training Mode feature which limits speed of the car for easy learning (Default setting at the time of shipment is Training Mode).
    Gyro Compatibility
    Equipped with special mount space and gyro adjustment volume dial for the optional gyro unit MZW446 (sold separately).
    Drift Tires and Full Bearings
    Comes equipped with drift tires as standard and 14 ball bearings.
    • MINI-Z AWD Readyset based on MA-020 chassis
    • Special circuit board updated with optimized steering control program
    • Chassis features gyro sensitivity adjustment function
    • Drift tires are installed as standard
    • Readyset requires only batteries to be ready for action!
    • Features 2.4GHz Syncro KT-531P transmitter that requires no setup of frequency bands
    • Factory completed body comes with display model quality finish
    • Features VCS (variable camber suspension) that adjusts camber in accordance with suspension stroke
    • Coil spring on front suspension can be easily replaced without tools
    • Kyosho Mini-Z Torch Red Dodge Challenger SRT Hellcat Redeye 1/27 Scale AWD Car - RTR
    • R/C unit built-in complete chassis
    • Painted and marked complete body
    • Syncro KT-531P transmitter
    • Mini pylon
    • Pinion gear (15T, 17T, 19T, 21T)
    • Spur gear (27T, 29T, 31T)
    • Spare nut
    • Wheel wrench
    • Pinion removal tool
    AGE LEVEL : 11 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/27
    Length 171mm / 6.7in
    Width 75mm / 2.9in
    Height 50mm / 1.9in
    Weight (No Battery) 193g / 6.8oz
    Wheelbase 98mm / 3.8in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis MA-020-W
    Drivetrain AWD
    Wheel Size (Diameter x Width) F: 25mm x 8.5mm R: 25mm x 11mm
    Wheel Hex Size N/A
    Tire Tread F: 64.5mm R: 62mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 7.23, 6.38, 5.71, 5.97, 5.34, 4.97, 4.5:1
    Final Drive Ratio N/A
    Pinion 15T, 17T, 19T, 21T
    Spur Gear 27T, 29T, 31T
    Differential N/A
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Servos N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Smooth paved surfaces
  • JaniceBowers
    • May 2024
    • 3
    Patients suffering from depression may benefit from lemon skunk's mood-boosting effects. The strain's ability to induce euphoria and uplift the spirits can provide temporary relief from depressive symptoms, dabbing​ offering a more positive outlook and increased motivation.​
