Official Primus PC12 Ibex 1/12 Scale 4WD Crawler Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Version Info: Fully assembled and ready-to-run, this model requires the addition of two AA alkaline batteries for the transmitter (not included).
    Now available from Motion RC, the compact, feature packed Primus PC12 Ibex 1/12 scale RTR crawler will exceed your expectations of performance, durability, and affordability! Arriving fully assembled and ready for action in your choice of three colors, this impressively realistic model is uniquely sized at 1/12 scale, making it suitable for use indoors or outdoors. The PC12 Ibex features include a full-time 4WD system, traditional link-style chassis arrangement with coil-over dampers, molded hard plastic body with complete interior, LED lighting system, a powerful, water-resistant brushed motor and more!
    Elevate your crawling game without depleting your wallet by combining the versatile, durable, compact crawling performance of the Primus PC12 Ibex 1/12 Scale 4WD Crawler with Motion RC’s industry-leading customer service, product selection, and complete parts support for a package that cannot be beat!
    Complete Package
    The 1/12 scale Primus PC12 Ibex RTR arrives assembled and ready to run. Install your choice included scale accessories, add 2 AA alkaline transmitter batteries and be prepared for an exhilarating crawling experience!
    Capable Crawler
    The well-appointed chassis features a traditional 4-link layout, molded side guards, bumpers, and more!
    Easy Access
    The battery pack is conveniently located, allowing removal for charging without removing the body shell.
    Well Appointed
    In addition to an array of molded plastic details, the PC12 Ibex features opening doors that unveil a completely detailed interior which easily accepts 1”:1’ scale dolls or action figures to individualize your ride.
    • Fully assembled and ready to run
    • Unique 1/12 scale size allows both indoor and outdoor use
    • Molded ABS plastic body with opening doors and complete interior
    • 4WD with capable 4-link crawler suspension
    • Comfortable and capable 2.4GHz pistol-grip transmitter
    • Runs over 30 minutes on a charge
    • High-grip crawler tires mounted on realistic wheels
    • Included details include roof rack, wipers, mirrors and more!
    • Realistic LED light system
    • Easy-access battery pack allows convenient removal for recharging (from underneath without removing body)
    • Available in three colors
    • Primus PC12 Ibex Black 1/12 Scale 4WD Crawler - RTR
    • 2.4GHz transmitter
    • 2S 7.4V Li-ion battery
    • USB charger
    • Quick start guide
    • Optional foam wheel inserts
    • Injection-molded detail parts
    • Tools and spare parts
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 30 Minutes
    Model Scale 1/12
    Length 390mm / 15.2in
    Width 190mm / 7.4in
    Height 210mm / 8.2in
    Weight (No Battery) 1,595g / 57oz
    Wheelbase 230mm / 9in
    Ground Clearance 48mm / 1.9in
    Body Molded ABS plastic
    Chassis Composite
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 82 x 30mm
    Wheel Hex Size 12mm
    Tire Tread All-terrain
    Bushing Material Oilite bronze
    Suspension Four-link with dampers, solid axles
    Shock Type Coil-over friction dampers
    Transmission Gear
    Gear Pitch M0.6
    Internal Gear Ratio 12.5:1
    Final Drive Ratio 49.6:1
    Pinion 14T
    Spur Gear 70T
    Differential Locked
    Ball Bearings N/A
    Brakes Electronic
    Electronic Speed Control 50A with SM3P connector
    Motor 390 brushed
    Battery 2S lithium-ion (included)
    Servos Waterproof
    Radio 2-channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 30 minutes
    Recommended Environment Indoors/Outdoors
  • mish
    • Jan 2024
    Anyone know where I can get extra batteries? I’m concerned that there is only a 3-pin connector for charging and running the car. My other cars have a 3-pin connector for balance charging and a 2-pin connector to run the car. I’m concerned that those batteries might not be compatible.
    • hooked on hobbies
      • Apr 2021
      • 19
      • California
      you can use this battery: https://www.motionrc.com/products/di...tor-dcm25000-0
