Originally posted by Alpha
View Post
The problems with this longer barrel are one, that the Leopard 2s equipped with it cannot fire the 120mm U.S. or similar made rounds as the ballistics are far different and the Leopard 2 fire control computer is reported not to be able to adjust for the difference. The same goes for the A2 Abrams firing the rounds intended for the longer barrel. The second problem is the barrel is so long it greatly increase the difficulty with maneuvering the tank in the already tight terrain environments of the European landscape like the typical old world villages, large cities and dense forest. Third and to a lessor degree for the German army is transport by air. Because of these draw backs it is common to see other countries that use the newer model Leopard 2 using the "original" shorter barrel as used on the A2 Abrams as it allows for the use of U.S. and standard NATO 120mm rounds yet does not add to the maneuvering issues.
With regard to the Heng Long Leopard 2 and using it in IR battling the issues of the longer barrel is clear and it is a harder tank to fight effectively with. The Heng Long Abrams with its shorter barrel yet similar overall size is an easier tank to maneuver in a simulated city scape or heavily brush laden battle field. It is not uncommon to see modified "shortened" barrels on Tamiya and Heng Long Leopard 2s that are used in IR battling, these typicaly represent non German army late model Leopard 2s.
