Heng Long sells its 1/16 scale RC tanks in four primary editions: Original, Upgrade, Upgrade A, and Professional. The higher the edition, the higher the metal parts content, features, and cost.
The "Pro Plus" is a *possible* fifth tier, envisioned as a very limited production edition above the Professional edition, that I've been working on with Heng Long this year. Essentially, it takes an Abrams Professional Edition (metal road wheels, idler wheel, sprocket, and tracks), and adds the following upgrades:
1) Full metal lower hull, separable from upper hull via CNC clamps (no screws required)
2) CNC Adjustable idlers
3) CNC Fully Enclosed gearboxes with steel gears, bearings, and 390 motors with a fast gear ratio befitting a modern MBT
4) Genuine torsion bar suspension
5) 2s 7000mAh battery with onboard charging via functional hatch on the rear engine deck (3s capable)
6) 360 degree turret traverse
7) Dual smoker units, both upgraded to CNC heaters (Each about 5s the volume produced by the stock smoker unit)
8) Dual speaker (one bass, one tweeter) in resonance chamber enclosure
9) Servo driven barrel recoil
10) LED barrel flash
11) Barrel smoke (via dedicated smoker inside the turret
12) Prototype TK6.1S 160 amp MFCB
13) Retains the use of IR Battle functions
14) Taillight and turn signal upgrades
15) Provision for a function APU to power additional beacons or FPV in the turret (3DPUP CITV)
The point of this thread is to document the personal customizations I do over time to this test platform. I also hope to garner feedback and suggestions from other tankers regarding this potential "Pro Plus" series. Are these features that there is a market for, even at this high price point? Which other models would tankers want to see receive the "Pro Plus" treatment, with barrel flash/smoke/recoil, torsion bar suspension, and onboard charging?
Heng Long and Motion RC are willing to meet customer preferences for more elite editions up market, if and when such a demand materializes.
For now, enjoy the journey.
to the tank, keep it up!
