In this thread I'll be comparing some of the lesser known MFCBs available for RC tanks. This thread will document debugging, testing, and an eventual assessment of the advantages and disadvantages of each system. If any of you have experience with the Can Shuo CSTK16 or the Weiheng WH.T16Z, please also post your thoughts!
Both of these MFCBs are used to replace the stock MFCB in an RTR tank such as that from Heng Long, Hooben/Ark, Taigen, Torro, etc. Users then bind their own radio of choice to their receiver of choice, such as a Futaba 8J, then set about programming mixes and assigning switches where they choose.
Both of these MFCBs have unique features, but also several common functions, including:
1) Dual speaker output up to 12W
2) Barrel Recoil and Elevation
3) Barrel Elevate-To-Reload (such as Leopard 2A6)
4) Many LED output ports, including barrel flash LED (the Weiheng can power a 10W xenon flashbulb)
5) Ability to control either conventional double motor or transmission-based dual motor drive systems
6) Input voltage 2s-3s
7) Wider sound set selection (CanShuo has five onboard sound sets, whereas the Weiheng can only be flashed with one at a time)
8) Higher amp ESCs and mosfets
9) Aluminum case
10) Comprehensive owner manuals and setup guides (if you can read Chinese like I can)
9) Aluminum case
:exploding_head: It`s i,m,h,o, a very good board so I can`t believe the lack of info on it? Its way cheaper, for it spec, than the IBU`s I have in my other tanks, 1/2 track/s etc! PS. I`ve just had, this AM, an e-mail from Hooben admitting to thier `mistake` in sending me (in UK) my `Master Edition` Merkava 4M, RTR tank, with ALL the supplied RC gear, FS-i6s (TX) and the CS-TK (mfu) all set up in Chinese!.........you think! Don`t, yet, know what they are going to do about it? Thanks, in anticipation, Chris-R.
I`ve been asked to send a video to Hooben, now done, to " show their engineers" to help get a `speedy` fix for all of this, we`ll see eh! :anguished: Once again, thanks so much for your help. Chris-R
