  • DavidN
ID:	371214Click image for larger version
  • DavidN
    And my collection of Panzer IVs..... Click image for larger version
ID:	371210Click image for larger version
  • CountChocula
    Originally posted by cpt.chaos canada
    Looks good to me.
    What scale are they?
    I guess 1/35?
    CCC
    They're 1/18th Ultimate Soldier I believe. They're IR battle ready although I'm still working on a more solid track solution for both.
  • cpt.chaos canada
    Originally posted by w68colley
    My 1st tank, can't wait to get outside.
    Congrats and the Walker Bulldog is a fantastic choice for outdoor operations.
    CCC
  • cpt.chaos canada
    Originally posted by CountChocula
    Here’s a couple of my kit bashed vehicles. Not to scale or much detail but fun to make work.
    Looks good to me.
    I guess 1/35?
    CCC
  • DavidN
    It is best for the tank in running it outside if you can reverse the tracks the other way
  • 761st
    Welcome to it!
  • w68colley
  • CountChocula
  • CountChocula
  • DavidN
ID:	371077Click image for larger version
  • DavidN
ID:	371074Click image for larger version
  • DavidN
  • DavidN
    My collections of Panzer IIIs.....
ID:	371068Click image for larger version
  • Vaseline
    Man it all went together fantastic
    Again nice work
  • Rubicon99
    Originally posted by Vaseline
    Rubicon that is an amazing tank I'm assuming you printed all the ERA and turret but a great piece of work always fun to see
    Nice work
    The ERA / EMA, barrel and up armored turret hatches are 3D printed. They were designed by JVM3Dconcepts to my specifications. The turret off as a stripped down Henglong ZTZ 99A turret and modified to fit onto the T72 hull. Other small parts are kit bashed (taken) from a Leopard 2, Bradley, T90, Leopard 1 and Abrams.
  • Vaseline
    Nice work
  • Rubicon99
    Originally posted by oldwolf
    Rubicon99, your T72 GX-2 looks great! The main gun bore looks smaller than on most model tanks. Are you using a smaller diameter main gun bore to narrow the ir beam and force yourself to take more precise shots?
    The barrel is a custom 3D printed resin barrel with metal sleeve inner bore liner. The bore is slightly smaller then the stock HL “bb’ bore, but large enough to fit an IR (or flash) bulb snuggly. It is the same bore size I fit to most of my tanks ( I remove the forward section of HL inner barrel or I add tubing inside to reduce the inner diameter) it tighten the beam slightly but not some much that I handicap myself with a much slower aiming speed. The bulb set back is slightly further back in the barrel at 10mm on this tank. Overall this tank was built with a much larger and different playing field in mind that see engagements at 50 -100+ ft routinely and high speed maneuvering (modern theme A.I.M. battles) like that of the San Diego club or lessor degree PHX club. The LA field is just to small but made for a good “live fire” trials day for it.
  • oldwolf
  • Rubicon99
    T72 GX-2 at its first battle day with the LA tank club 02/11/23
ID:	370144Click image for larger version
ID:	370143Click image for larger version
ID:	370142Click image for larger version
