IR "Tank in Attack" photos from past events and battles....
  • #21
    Close in dual between a Tamiya M51 Sherman and Heng Long 6.0 T34-85 that ended badly for one?
ID:	226299Click image for larger version
    • #22
      From the Jan 5th LA TANK first battle day of 2020.
      Click image for larger version  Name:	F4A0BA86-3AF5-4326-B93B-68D92293E541.jpeg Views:	0 Size:	141.9 KB ID:	226489Click image for larger version  Name:	FC9CCF61-2B97-466C-9191-1F069BC1CE9E.jpeg Views:	0 Size:	209.9 KB ID:	226488Click image for larger version  Name:	AAE334C0-7567-4DE3-88A3-165A55C210F7.jpeg Views:	0 Size:	141.0 KB ID:	226487Click image for larger version  Name:	98DA4E5F-D387-4803-9A1D-59CF9A5F7353.jpeg Views:	0 Size:	165.8 KB ID:	226484Click image for larger version  Name:	BF295C84-901C-4A92-9636-A712A6040AC1.jpeg Views:	0 Size:	230.7 KB ID:	226485Click image for larger version  Name:	E02FE34D-8697-4A02-A9DE-7AFECE8B47E3.jpeg Views:	0 Size:	227.7 KB ID:	226486
      • #23
        Feb 2, Battle Day at LA Tanks. Team M41 ready to roll out and deliver some carnage to the opposing team.
        For more photos see Instagram @fsttanks
        • #24
          Just a few from the March 2020 IR battle day with LA Tanks. I have post on Instagram @ fsttanksClick image for larger version  Name:	18A6626F-F756-43E4-BBA4-BA4648B4952B.jpeg Views:	0 Size:	365.6 KB ID:	239191Click image for larger version  Name:	B3A00A84-B919-4FA6-BED0-9087DD48F834.jpeg Views:	0 Size:	334.8 KB ID:	239190Click image for larger version  Name:	616B8301-02FC-4CE7-9C88-0F88D305DA40.jpeg Views:	0 Size:	305.8 KB ID:	239188Click image for larger version  Name:	F86B828B-05E2-4625-8F46-A4B6C13759E2.jpeg Views:	0 Size:	317.5 KB ID:	239189
          • #25
            • #26
              Ha Phil, where are you from. Your profile photo looks like Cascade Flier's field in Central Oregon.
              • #27
                I have posted the dates for the Texas Armor Association battle dates in the events section. We are just outside of Houston TX at Bomberfield and meet up monthly.
                • #28
                  Rudinater , Welcome to Hobby Squawk. "Tanks" for joining us here. Best, LB
                  • #29
                    Thanks so much for joining the squawk Rudinater ! I am the one who approved all the events. Thanks so much for posting them!
                    • #30
                      Hi Rudinator, yes, that's right, we live in LaPine, and run my tank in the back yard,... we can try and get together this spring..!
                      • #31
                        Cool I should be back in Bend for the summer around the end of May.
                        • #32
                          OK, we'll see you then..!
                          • #33
                            Bump
                            • #34
                              A few from the battle day testing of the new aftermarket Heng Long 6.0 IR receivers. All the tanks shown are using the new IR receivers.
                              Also see my Instagram @fstanks
                              Click image for larger version  Name:	CABB6F3F-1CF9-4AB4-AD6F-673BC0A85509.jpeg Views:	0 Size:	206.3 KB ID:	245936Click image for larger version  Name:	E241C025-9073-4ED1-8F11-85781B6291A6.jpeg Views:	0 Size:	194.8 KB ID:	245937Click image for larger version  Name:	474A9B13-336F-4956-8C45-7BB68E5CF8B1.jpeg Views:	0 Size:	261.7 KB ID:	245938Click image for larger version  Name:	77E145B9-D89E-4550-A743-476A3CB6CF2F.jpeg Views:	0 Size:	375.2 KB ID:	245939Click image for larger version  Name:	E955FF01-226F-4F7C-98FA-C4168CE07F8E.jpeg Views:	0 Size:	252.1 KB ID:	245940
                              • #35
                                I like the inexpensive and creative use of cardboard box and styro cooler for buildings.
                                • #36
                                  It doesn’t need to cost or take a lot of time to make a small village filled with simple structures to add some flavor to a battle field.
                                  • #37
                                    This looks like fun.
                                    I see that LA Tank has a monthly get together by Whittier Narrows. Once the lock down is over I'll go check it out. I've never flown at the air field at the Narrows so I can check that out as well.
                                    Thank you for sharing your photos.
                                    Yield to temptation. It may not pass your way again.
                                    R. A. Heinlein
