Heng Long 1/16 Scale "Panther" Tank
Introduction:
Based on a theoretical pairing between a Tiger I and a Panther G, Heng Long's Panther or "Pantiger" as it is known in the RC tank world, emphasizes RC-friendly handling over scale historical provenance. To me, the most appealing aspect of this "PanTiger" is that it frees up the modeler to interpret his/her tank without the constraints of historical accuracy. Because I have more than a dozen "historically accurate" tanks already, I plan to custom refinish my PanTiger in the spirit of an Akira-themed tank, or The Mandalorian. All of Motion RC’s Heng Long 1/16 scale tanks utilize the latest TK6 MFCB for outstanding control, performance, playability, and upgrade potential, so whether you choose to keep the stock WW2-themed colorway or personalize it with your own flavor, the PanTiger runs as reliably as the popular Heng Long Tiger 1, which shares virtually the same lower hull.
For the Tiger 1's review, click here
Functions:
Featuring the latest TK6 Multi-Function Control Board (MFCB), Heng Long's Panther "PanTiger", like its other TK6 series 1/16 scale tanks is full of features:
1) Proportional acceleration, steering, turret traverse, and gun elevation/depression
2) Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed and low speed modes, etc
3) Smoke effect (On/Off)
4) Headlights and Brake lights (On/Off) *note, the real Panther didn't have brake lights, so neither does this RC tank, but the MFCB does have extra ports for lights to be added if you choose
5) Volume (five settings including Off)
6) Four different Sound Sets. Each Sound Set contains a unique engine start sound, idle sound, accelerating sound, traverse sound, elevate sound, machine gun, cannon firing, and shutdown sound.
7) Track Recoil (Three settings from low, medium, and high) --This shudders the tank briefly rearward to simulate recoil when firing the main cannon. The Low or Medium settings are more realistic.
8) Fires a 6mm plastic BB (~10 meters with minimal accuracy and limited velocity, but should still be treated with caution and with adequate eye protection)
9) Fires an invisible IR signal to be used as part of Heng Long's Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
10) Independent suspension on all road wheels
FEATURES:
- Latest Generation TK6 Multi-Function Control Board (MFCB)
- Proportional acceleration, steering, turret traverse, and gun elevation/depression
- Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed and low-speed modes, etc
- Smoke effect (On/Off)
- Headlights and Brake lights (On/Off)
- Volume (five settings including Off)
- Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
- Track Recoil (Three settings from low, medium, and high) -This shudders the tank briefly rearward to simulate recoil when firing the main cannon
- Fires a 6mm plastic BB (10 meters with minimal accuracy and limited velocity, but should still be treated with caution and with adequate eye protection)
- Fires an invisible IR signal to be used as part of Heng Long's Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
- Independent suspension on all road wheels
- Heng Long German Panther Upgrade Edition 1/16 Scale Battle Tank - RTR
- 2S 7.4v 1800mAh LiPo battery with Tamiya connector
- 2S LiPo battery charger
- 12-Channel 2.4GHz radio transmitter (Requires 6 AA batteries)
- Magnetic Infrared (IR) battle system receiver
- Painted cosmetic accessory parts
- Adhesive decal sheet
- 6mm plastic BBs (50 Pack)
- 2x spare track links
- Complete instruction manual
Durable Tracks Confidently conquer terrain with durable tracks that are easy to service. The "Professional" edition features metal tracks. The more affordable "Upgrade" edition, pictured here, uses lighter painted plastic tracks and wheels. I didn't have many problems with these wide tracks, as they distribute the tank's weight across a larger area. The resulting reduced ground pressure provides a maneuverable tank that plows through most dry surfaces with ease. |
Independent Suspension and Steel Geared Gearbox Reliable steel geared gearboxes transfer power while independent suspension provide traction over rough surfaces. Both the Professional and Upgrade editions of the Panther, and for that matter all of Motion RC's TK6-equipped tanks from Heng Long, use steel gears. Say goodbye to fragile plastic or zinc alloy gears! |
Omnidirectional Proportional Control The latest generation TK6 Multi-Function Control Board (MFCB ) provides smooth driving response and personalized configuration options. Detailed at the top of this post, the MFCB's functions effectively render all previous versions obsolete. Heng Long's older versions, including the previous TK5.3, is far less capable and lacks all of the TK6's major improvements in control, functionality, programability, and playability. |
Airsoft BB Launch Safely fire 6mm plastic airsoft BBs at the included paper target at short ranges. *Take safety precautions and wear eye protection. |
| Scale Detail The perfect balance of scale detail and practical RC Tanking, each Heng Long tank arrives factory painted and includes Cosmetic Accessory Parts to further enhance the tank's realism. Because the Panther or "PanTiger" as it has come to be known is not a strictly historical armored vehicle, Heng Long has adapted the lower hull of a Tiger 1 and the upper hull design cues of a Panther G. The usual amount of detail on early Heng Long tanks is present on this PanTiger, including clip-on spare track links, stowage, and unditching equipment. |
Realistic Operation 320 degree turret traverse, 30 degree cannon elevation, programmable track recoil, and four different sound sets put you in complete control. I left this PanTiger in the first sound set as it was delivered out of the box, which is the classic "Heng Long Rumble" engine sound. |
| LED Light A single white LED headlight indicates the tank's standby and active modes, and also flash when "hit" during IR Battles. |
Exhaust Effect Glycerin-based "exhaust effect" simulates engine exhaust for added realism. I found that the newer 2020 exhaust effect smoke generator operated more reliably than the PanTiger I owned over ten years ago. Having toured the factory, I have see the improvements in assembly and QC that directly contribute to longer lifespan of these typically finicky units. |
| RTR The convenience of "Ready to Run" (RTR) allows new players to join the world of RC Tanks with ease! The Panther / PanTiger arrives pre-painted as shown, with simplified cosmetic assembly parts that make it easy to get this tank out of the box and running. By the time the drive battery was charged, the tank was ready for its first sortie! |
