Surprise find
  • Sappo
    • Feb 2020
    • 346
    Surprise find
    While monkeying around with the idlers on the Abrams look what I found Click image for larger version
ID:	249848Click image for larger version
  • Sappo
    • Feb 2020
    • 346
    Didn't know that the base version had adjustable idlers. Ok it means you have to take the wheel off but it saves having to break track. Handy to know for the future
    • Rubicon99
      • 3316
      The old 5.3 version did not have the ability to tension tracks. All the new 6.0 Abrams have this improvement. It has done a lot to make the 6.0 Abrams a far more reliable running tank then the last 5.3 version was especially with aftermarket metal/rubber padded tracks.
      Why HL does not point it out in the manual????
      • Sappo
        • Feb 2020
        • 346
        This is the 5.3 version. That's why I got a bit of a surprise when I discoverd it
        • Rubicon99
          • 3316
          You lucked out!!! Got one of the first new hulls 👏👏👏 . That makes it worth upgraded to the 6.0/1 system👍👍 down the road.
          • Sappo
            • Feb 2020
            • 346
            Thought it might be something like that. Have heard of other 5.3s with 6.0 features before.
            • Rubicon99
              • 3316
              It’s not to common. But has happened.
              • Sappo
                • Feb 2020
                • 346
                And I'm so happy it has
                • rzing
                  Let's put one up!
                  • Jul 2016
                  • 18
                  • Fond du Lac, WI
                  Just checked my 6.0 Tiger 1 with metal gears, drive sprocket, idler, and tracks. It does have the idle wheel adjuster. Just loosen the screw and there are sort if ratchet teeth on the back side that engage "teeth" on the hull side to lock in the position. Don't know if earlier versions had it but I'm glad mine has. Nice!!!
                  • gunslingeru
                    • Apr 2020
                    • 4
                    I just got the 6.0 tiger. I only see four screws on the bottom of the tank. Middle and back half. I’ve removed them, but the front still seems to stick. Is there a screw somewhere that I am missing?
                    • Delizar
                      Perpetual Noob
                      • 88
                      • SoCal
                      Remove the Fake tracks from the front lower glacis there are 2 screws hiding under there.
                      Yield to temptation. It may not pass your way again.
                      R. A. Heinlein
