IR Battle Reciever
  • Arcright
    • Mar 2020
    • 16
    IR Battle Reciever
    Anyone got a pin out drawing for this ?
  • Beeg
    • 1335
    • Texas
    That link goes to a log in page....
    • Rubicon99
      • 3316
      https://www.etsy.com/uk/transaction/1836941822
      How about a photo or name of the IR receiver?
      • Arcright
        • Mar 2020
        • 16
        Is this any better
        This Electronic Toys item by LegoDEI has 17 favorites from Etsy shoppers. Ships from United States. Listed on 27 Mar, 2023
        • Rubicon99
          • 3316
          Yes those are excellent. I worked with LegoDEI on developing those for the 6.0 HL tanks. There are three specific types, one for Clark & IBU, one for Tamiya and one for the 6.0 HL tanks. Which layout were you looking for. You can also PM LegoDEI here on HS he is a member and can more fully answer your questions.
          Click image for larger version  Name:	F7C277BA-86B6-41D5-AD08-E8DFB2523100.jpeg Views:	0 Size:	173.6 KB ID:	256269The pin layout is listed on the bottom all the LegoDEI receivers. This one is for the 6.0 HL tanks. The three pins circled in red are for the IR receiver and the other two are for the optional use of tying in the LED hit indicators to the taillights.
          • Arcright
            • Mar 2020
            • 16
            My MFU is an IBU2 so if I can get the pin out I can make up a wiring loom, the Tamiya IR supplied has no markings on the underside PCB
            • Rubicon99
              • 3316
              I would suggest not buying the one for the 6.0 HL system and making sure you buy the one for the Clark/IBU system. If you are not sure which one then I would recommend contacting LegoDEI directly. As stated above he is a member here and you can PM him your questions to ensure you order the correct IR receiver.
              Below is the pin layout for the non HL IR systems. This one is for the Clark/IBU systems. It follows the same layout as the Tamiya IR receivers.
              Click image for larger version  Name:	E918564A-E673-4FC5-95DD-4358A7CF884C.png Views:	0 Size:	250.9 KB ID:	256273
              • Arcright
                • Mar 2020
                • 16
                This is the version I already have?
                • Rubicon99
                  • 3316
                  That is the Clark/IBU version. The wire layout is the same as the blk&wht photo above in my prior post.
                  • LegoDEI
                    • Mar 2020
                    • 100
                    Arcright There're only two types now. I have made a universal type that works with Tamiya, Clark, IBU, and another that works with HengLong. The one that you have is the Tamiya/Clark/IBU compatible one.
                    I have updated the listing to re-include the pin-out. I originally removed it since I assumed most people had the base/mount with the semi-circle on one side and would use that for alignment.
                    Either way, here is the pinout as well attached for your convenience. Thanks to Rubicon for chiming in with that additional info! Please note the updated voltage ranges.
                    Importantly, the Tamiya/Clark/IBU version runs nominally off of 5Volts with some range of tolerance, and the HengLong version runs off of 3.3V.
                    Click image for larger version  Name:	Clark_pinout.jpg Views:	0 Size:	153.1 KB ID:	256297
                    • Arcright
                      • Mar 2020
                      • 16
                      Thanks everyone for the help I can crack on now and make up the mounting 😁
                      • karltrek
                        karltrek
                        • 159
                        • Santa Cruz, CA
                        I finished modding my new IR receiver. I tore apart a stock IR receiver and repurposed the base, magnet, wires, and plug. I wanted it to be easily moved from tank to tank. I am not going to set up the LED function. I used a small foam disk as a standoff between the base and the IR unit. Then painted it all flat black. It works great too! 😃
