T34 or T34-85?
  • I_Tank
    • Jul 2020
    • 6
    • Southern California
    T34 or T34-85?
    I noticed the T34 that is coming soon looks a lot like a T34-85 is the picture wrong or the description. Either would be great I am looking for the T34 though 😊👍
  • Rubicon99
    • 3311
    It is a T34-85. The use of T34 is generic for the tank just like the name Abrams or Sherman of which there are numerous variations as well.
    There are aftermarket conversion kits that can backdate the HL T34 to older versions so you have options.
    • SoCalBobS
      • 2717
      Here's one option I'll be working on, a T-34/76 1940-1942 turret conversion. I got this one off eBay from a seller it St Petersburg, RU. It'll be my first servo elevation and hopefully cannon recoil project. I'm using a 6.1S board for it.
      If anyone wants to know, this turret will require MAJOR work. The exterior looks okay, but the interior has nothing; no place to attach a turret ring, surface is just a blob. But, if I can get it to work, it'll be an IR battle force to be reckoned with. I won't have to take anything from my /85 turret, so I can always go back.
      (This post is a thread bump from a year ago!)
      • Rob1970
        Grumpy Old Dutchman
        • Jun 2021
        • 278
        Oh great... there's options!? And just when I thought the T34-85 I have incoming would just need a little weathering...
        Sherman M4A3 105mm Houwitser / Sherman Firefly IC *under construction* / Panzer IV *awaiting side-grade from TK7.0S to TK6.0S* / Stug III / King Tiger / KV-1 *awaiting upgrade to TK6.0S* / Tiger I / T34-85 / Leopard 2A6 *waiting upgrade to TK7.0*... No, I do not have a problem....
        • DavidN
          • May 2021
          • 3189
          • Los Angeles, CA
          Such a coincidence! I am current working on the Russian tanks as well. One of them is the SU-100. The other one is the T34/76 1943 with the hexagonal turret. I took the turret out of old Trumpeter kit.
          • DavidN
            • May 2021
            • 3189
            • Los Angeles, CA
            Somewhere east of the Ural mountain, a Russian factory is building more tanks to face the German's panzers :-) These are what I am working on. I will put the HL 6.0S inside both of them.
            • Vaseline
              • 290
              David where is you come up with the Su 100 Nice tanks Thanks I have been looking for one
              • DavidN
                • May 2021
                • 3189
                • Los Angeles, CA
                It's a Trumpeter model kit. It was a tough decision to buy it since I only used all the parts of the upper hull.
ID:	321597Click image for larger version
                • DavidN
                  • May 2021
                  • 3189
                  • Los Angeles, CA
ID:	321601Click image for larger version
                  More $ but less work than those resin conversion kits :-)
                  • Vaseline
                    • 290
                    Thank you for the time I have always like the Su 100 over the 122 or 152 Thanks again for showing and sharing
                    • DavidN
                      • May 2021
                      • 3189
                      • Los Angeles, CA
                      Yes! I like the SU-100 a lot too. It looks better than the bulky SU-122. I have ordered the RC parts. Hopefully I get to finish the paint job and the weathering before the RC parts arrive.
                      • Vaseline
                        • 290
                        I haven't found a resin conversion yet. So if I want one I will just pony up and get a Trumpeter kit.
                        • DavidN
                          • May 2021
                          • 3189
                          • Los Angeles, CA
                          I have been looking to have the RC 1/16 SU-100 for a long time. My final approach was the Trumpeter kit. It was easy to work with. No warped piece, no drilling, sanding, or dremeling. There are plenty of room for future gun elevation and IR system set up.
                          • DavidN
                            • May 2021
                            • 3189
                            • Los Angeles, CA
                            I also did the same with my T34/76 1943.
                            • Vaseline
                              • 290
                              Good deal
                              • SoCalBobS
                                • 2717
                                Interesting thread here, especially about the Trumpeter kits. I bought a T-34/76 turret from an eBay seller in St Petersburg. The exterior is ok, but the interior is a mass of lumps, hard to work with. The mantlet, trunnions and pintles are not symmetrical. Looking at it, and now at pictures of the Trumpeter, I'm guessing someone just made a mold of their turret.
                                So, not a good value, I wouldn't recommend it, but when it's done it will undoubtedly look cool! I couldn't remember what color I used for the original T-34/85, but I think I guessed right. When I dirty it up, it should match.
                                Oh by the way, since I had the turret off, I decided to alter the gear ring to make it 360 degree capable. Very easy. The gears are rough enough that as long as the teeth look similar, you won't even detect a difference in operation.​
                                • DavidN
                                  • May 2021
                                  • 3189
                                  • Los Angeles, CA
                                  Bob! Thank you sharing Bob. I had just finished painting my T34/76 1943 today. Not much of a work. Just repainting, weathering, putting on decals and coated it. I will work on the mechanical interior when all my parts that I had order arrive.
                                  • DavidN
                                    • May 2021
                                    • 3189
                                    • Los Angeles, CA
                                    And here is the SU-100:
ID:	321827Click image for larger version
                                    • DavidN
                                      • May 2021
                                      • 3189
                                      • Los Angeles, CA
                                      Group picture before they are sent off to their units
ID:	321830Click image for larger version
                                      • SoCalBobS
                                        • 2717
                                        Finished the conversion, mostly. The turret rotates 360 degrees, the barrel has servo elevation. An IR bulb is mounted in the barrel. No airsoft. The hatch is hinged. Still needed is servo recoil. If anyone has photos of their homemade recoil setup, please post them! The decals are Archer Fine Transfer dry decals, great since there is no film around the images. I weathered the turret to match the body, but it needs to be run in the dirt since much of the texture of the tank is real dust from battles.
                                        I didn't have to scrounge anything from the 85 turret, so I can always "update" the tank!
