I noticed HL gearboxes are a bit sloppy and noisy with some unevenness when running straight. Decided to go through them replacing the bushings with flange bearings, add shims, and clean things up in general. It was pretty straight forward, but the shafts on the gears are 3.5mm, and I could only find 4mm ID bearings, so I made press fit bushings from brass tubing. The gearbox needed to be drilled to accept the 7mm OD flange bearings.
Once finished without the motor installed I could flick the input gear and the entire gear train would spin freely. Up and running there's a major reduction in gear noise, steering is smother and crisper with less speed loss, and will creep smoothly at a snails pace now.
It was worth the effort.
