Upgrade HL King Tiger with the BEST gear box possible.
  • dai phan
    • Sep 2020
    • 726
    Hi all,
    I would like to upgrade the HL KT with the best gearbox possible that is pretty much drop in fit. Can you recommend one? Thanks Dai
  • karltrek
    karltrek
    • 159
    • Santa Cruz, CA
    This is a drop in fit. All bearing and high quality. Higher speed Blue motors.
    https://www.ebay.com/itm/M-L-59mm-Ul...item342fa50cb8
    • dai phan
      • Sep 2020
      • 726
      I have heard about the red motors as well ? Dai
      • Rubicon99
        • 3316
        Originally posted by dai phan
        Hi all,
        I would go with a “black” Taigen 4:1 bearing gearbox. Opting for the upgraded 390 motors version. Taigen unlike HL’s red Ultimate gearboxes does not use brass finale gears or brass drive shafts. Taigen are all steel gears and shafts. I would also swap out the sprockets to theTaigen versions.
        You will lose some top end speed, but you will gain better low speed control and torque vs a red HL 3:1 Unlimited gearbox.
        • dai phan
          • Sep 2020
          • 726
          So with Taigen I need to buy new sprockets? I am still new at this so drop in w/o modifications will be appropriate. Dai
          • Rubicon99
            • 3316
            Yes drop in. But I highly recommend the Taigen sprockets to go along with the new Taigen black gearboxes. The drive shafts at times have a very tight fit with HL sprockets. You can get away with some very simple sanding of the Taigen shafts should the fit be to tight.
            Simply install the gearboxes. Hold some sanding paper on the shaft end and run the motor. At most it takes 5 or so minutes per shaft. It also allows for a “run in” time for the gearboxes.
            NOT all the Taigen gearboxes drive shafts need this it really depends on the HL sprockets. But to bypass any chance of needing to do it I recommend simply just buying the Taigen sprockets. They are cheap and slightly higher quality then the HL ones anyways.
            • dai phan
              • Sep 2020
              • 726
              Too bad all " SOLD OUT" at Imex and none on EB. Dai
              • dai phan
                • Sep 2020
                • 726
                Hi all,
                How about version 2? Better than Ultimate HL box? Dai
                • Rubicon99
                  • 3316
                  Hi all,
                  https://www.taigentanks.com/collecti...35669581037735
                  Yes it is a stronger gearboxes then the HL Ultimate. Also opt for a 4;1 which is slower but with more torque for better low speed control. Good match with a Tiger if you want realistic scale speeds. By simply adding the Taigen 390 4:1 pinion motors you can make it have even more torque. The motors can be found on Taigen’s website as a stand alone item.
                  • dai phan
                    • Sep 2020
                    • 726
                    I prefer V3 but since it is out of stock I will try this one. Dai
                    • dai phan
                      • Sep 2020
                      • 726
                      Hi all...
                      The Taigen gear box and idlers/sprockets for the King Tiger are here. Thank you Rubicon99 for your expert guidance. Dai
