Connection problem
  • garycook47
    • Jan 2021
    • 4
    • South Carolina
    Connection problem
    I am having problems matching Heng long receivers RX 18 v. 7 to a transmitter.
    Does anyone have issues with binding Taigen boards to a transmitter?
  • Vaseline
    • 290
    The old RX 18s are all 4.7Mhz and use a crystals to match freq. if I recall correctly, I never had a 5.3 so unsure if they used RX18s so I could be totally wrong too. But on the chance I am correct youll need a matching crystal set for your RX and your TX.
    • garycook47
      • Jan 2021
      • 4
      • South Carolina
      Thanks much answers my question. Unfortunately I bought three of these thinking the 7.0 was newer than the 5.3s. If you anyone who wants/needs them I will send them.
      • Rubicon99
        • 3311
        If you have a 7.0 it is the newest version. It can’t bind to anything but a 6.0, 6.1 and 7.0 system.
        If they have the older RX18 systems and they said it was a 7.0 then you got lied to. Your tanks can be upgraded to a complete 6.0+ system (TX/RX) relatively easily but it does require the complete removal of the old RX18 control board.
        • garycook47
          • Jan 2021
          • 4
          • South Carolina
          This is a pic of the back of the board.
          thanks,
          gary
          • garycook47
            • Jan 2021
            • 4
            • South Carolina
            Is this what you are talking about?
            thanks,
