Thought I would show an easy method for swapping metal shocks for the plastic ones on a Henglong Walker...
After removing the idler & tracks, I take a set of needle nose pliers and twist the upper shock mount which is pressed fit into place. The Pin has splines which grips the boss in the hull:
By twisting the pin, it free's it up, and allows it to come out just a tad. Trying to grab and pull it at this point gets nerve racking, as its pretty soft metal, not to mention the hull is plastic. I made a wedge/fork tool out of a bolt, which gets under the tiny gap created by the needle nose pliers. If you have ever removed a ball joint on a car, you know where this idea came from.
After its out a good way, then take the needle nose pliers and finish the job...
The head of the pins get chewed up just a little...cant be helped...need the grip of the teeth to free them up.
This is easily remedied by chucking up the pins in a drill, and hitting them lightly with some emery cloth...after which everything gets painted anyway.
Hope this helps....
Hope this helps....
