T90 problems
  • Sappo
    • Feb 2020
    • 346
    T90 problems
    Well I broke a track pin on the t90 today, didn't think much of it till I went to pull the pin out, its broken right at the end of the pin and what makes it worse is its the knurled end of the pin. Have tried tapping it out, broke my track breaking tool and am out of ideas. Normally would just remove the link but the track tension is set to the slack position. They are metal tracks by the way, anyone got any ideas?
  • Rubicon99
    • 3316
    Are you trying to do this while the track is on the tank?
    • Sappo
      • Feb 2020
      • 346
      No, the track is off,
      • SoCalBobS
        • 2754
        • Southern California
        One problem, or two? Do you have the spare pins that came with the track? If so, use a spare to from the other side push the broken one out. Or you can get a watch pin removal tool, on eBay for like $5 to remove it. If you don't have spare pins, maybe your local hobby shop has piano wire of the right diameter. Use some to push the old pin out, then make a new linkpin.
        • Sappo
          • Feb 2020
          • 346
          Broke the pin on my watch pin tool, bent a spare track pin, bought a 1mm drill bit and sacrificed it for the good of the tank, finally managed to get it out after soaking it in wd40, lesson to be learnt, don't break the track pin at the knurled end
