Heng Long Sherman decals
  • mrcub63
    • Sep 2021
    • 13
    I thought I saw a topic about Heng Long tank decals being a little difficult to apply?? and there were some tips? If so, please post any because of course due to my incompetence I’ve already ruined one, I followed the instructions, I cleaned the surface and waited after applying etc…the stars for the American tank is the problem, the tips of the stars are not adhering when I peel back…help lol and thanks in advance.
  • DavidN
    • May 2021
    • 3189
    • Los Angeles, CA
    My understand is that the plastic surfaces on these tanks are not very friendly with the HL decals. I found a Testor glossy clear coat spray can in my paint box. I sprayed on those areas that were for the decals to be applied on. The surface then would be glossy and should be good to apply the decals on. But I have to be very careful in positioning the decal. Once it is apllied onto the surface, it would be very dificult to pull it back up for repositioning. After that I spray a layer of dullcote to reduce the glossy effect. That's my method. Hopefully someone might have a better method.
    • mrcub63
      • Sep 2021
      • 13
      Ok, thanks…I’ll give it another try, I may just go the old water decal route and then go over that with something to protect it.
      • RichJohnson
        • 1276
        I use water slide decals or cut the star and circle out of blue tape and spraying paint on like a stencil. Paint mask insignias are also available. Both are better than HL rub and stick decals. The only things I use off the HL sheets is the ammo can stencils
        • mrcub63
          • Sep 2021
          • 13
          Ok, that stencil is another good option…I appreciate it
          • Kurtz
            • Aug 2021
            • 26
            • Southeast Texas
            Does anybody have a good source for 1/16 water slide decals? Allied and Axis powers..
            • DavidN
              • May 2021
              • 3189
              • Los Angeles, CA
              For the Allied, I got them from DAK RC.
              • SoCalBobS
                • 2716
                • Southern California
                Star Decals in Sweden (eBay) has a good selection of 1/16 decals. Shipping takes a while, though. 2 weeks +.
                Edit: oops, not much allies stuff.
