Tiger trouble.
  • GreektankerinTexas
    • May 2021
    • 5
    Tiger trouble.
    Suddenly had a problem arise where when starting up the tank it will make the typical engine startup sounds then start to flicker the lights and the sound stutters. When I push forward on the control stick it shuts down the tank. I can start up and repeat this process over and over. Looked inside and found no loose connections. Could the receiver be going bad? I have a video I posted on a Facebook page but can't seem to upload it here.
  • DavidN
    • May 2021
    • 3203
    • Los Angeles, CA
    Kindly let the members in the forum know which manufacturing company made your tiger!
      • May 2021
      • 5
      Apologies, the electronics are 6.0 henglong.
      • SoCalBobS
        • 2754
        • Southern California
        Not a lot of details from you to go by, but it could be simply a bad battery, low voltage. Either test it, put it on the charger longer or try another one if you can. Stock batteries are notoriously poor out of the box. A load such as a speaker or especially the motors will sag the voltage on a bad battery, even if it registers fully charged.
        • Cascabel
          • 99
          Sounds like a nearly dead battery to me......
