Suddenly had a problem arise where when starting up the tank it will make the typical engine startup sounds then start to flicker the lights and the sound stutters. When I push forward on the control stick it shuts down the tank. I can start up and repeat this process over and over. Looked inside and found no loose connections. Could the receiver be going bad? I have a video I posted on a Facebook page but can't seem to upload it here.
Tiger trouble.
Kindly let the members in the forum know which manufacturing company made your tiger!SoCal RC Tank Club Facebook Group
Gathering 1-2x monthly/All Ages & Experience levels welcome
Not a lot of details from you to go by, but it could be simply a bad battery, low voltage. Either test it, put it on the charger longer or try another one if you can. Stock batteries are notoriously poor out of the box. A load such as a speaker or especially the motors will sag the voltage on a bad battery, even if it registers fully charged.The more screws it takes to reassemble a tank, the more likely it is you left something out!
