Can I add a long barrel to my 1/16 Heng long Sherman?
Heng long Sherman
Gathering 1-2x monthly/All Ages & Experience levels welcome
- Likes 2
The panther barrel stuck in a howitzer Sherman makes my soul shudder.
But it’s your tank…RC tank parts and accessories I make
And Toucan Hobbies tricked me by stating that it was the Fury barrel. I guess I have to search for the correct 76mm barrel to replace it :-(Originally posted by RichJohnson View PostThe panther barrel stuck in a howitzer Sherman makes my soul shudder.
But it’s your tank…SoCal RC Tank Club Facebook Group
Dave, a Fella makes 76mm barrels but remember the turret on the henglong is a howitzer turret. It has the wrong mantlet entirely for a longer barrel. You could make a better swap out to a firefly barrel. The mantlet the Britts used was different but looked closer to the howitzer one on the heng long. I hate that vendors advertise that pantiger barrel as Fury just to sell them.
Heck it would look better if you just cut the german muzzle brake off the end.RC tank parts and accessories I make
I see that the more I learn, the more it shows that I know too little :-) Thank you Rich!SoCal RC Tank Club Facebook Group
Realistically the howitzer mantle, that holds the barrel, would never fit a longer barrel.
the 75mm Sherman has a barrel that is narrower but longer than the 105 howitzer but it has a different mantlet as well.
I suspect people are just tired of only having the howitzer turret on henglong tanks.
you could fit a different manufacturers turret for an accurate 75mm if you want to do some bashing but the only long barrel that was in a round turret was the Britts Firefly barrel. You could convert your tank to a firefly with some work.RC tank parts and accessories I make
So may I ask does the Torro/Taigen M4A3 75mm short barrel tank have the right turret for that short barrel?Originally posted by RichJohnson View PostRealistically the howitzer mantle, that holds the barrel, would never fit a longer barrel.
you could fit a different manufacturers turret for an accurate 75mm if you want to do some bashing but the only long barrel that was in a round turret was the Britts Firefly barrel. You could convert your tank to a firefly with some work.SoCal RC Tank Club Facebook Group
Yes the taigen / Torro is a proper 75mm. But the turret ring is bigger than henglong.
I think the mato 75mm turret is the same hull ring as the henglong size, but I’m not sure. I have never bought a mato turret, just the chassis.
https://www.ebay.com/itm/26519947774...ampid%3APL_CLKRC tank parts and accessories I make
Hi Richard! Can you clear up this HL M4 issue for me? Is the turret on the HL Sherman the correct size for the 105mm howitzer? I would like to know if the HL M4A3 has the right size turret :-)Originally posted by RichJohnson View PostYes the taigen / Torro is a proper 75mm. But the turret ring is bigger than henglong.
Here is the picture I have of the 75mm short barrel Taigen M4 (left) and the HL 105mm M4 (right). I measured and I think the HL turret is a little bit bigger (1/16 inch)
- Likes 2
Both Taigen and Henglong have fudged the dimensions a little on ther turrets and gun mounts and barrels to allow for the airsoft systems. But, I would venture a guess the turrets are probably pretty close to height and width of scale.RC tank parts and accessories I make
- Likes 2
No, the taigen shermans have a bigger turret ring than the henglong sherman.
I would suggest buying the taigen hull as well as the turret and mate it onto the henglong chassis. Or just save up and buy the taigen tank. They are way better than the HL any way.RC tank parts and accessories I make
