Your Picks on the Best Heng Long Tanks That You Own
  • DavidN
    • May 2021
    • 3189
    • Los Angeles, CA
    I don’t know if this was done in our forum before. As Christmas approaching, I feel that some of our members are in search of a tank to purchase. With our own top picks, they might feel more confident in getting that tank that they like and know a little bit about the tanks they are getting into.. For all those HL tanks you all have purchased, worked on, and played with, can you share with everyone your top picks on two or three of them. I only have 3 categories on my mind at this time. Please take your time and share with all of us your picks term of….
    1. Durability in running, upgrading, maintenance, and IR battling.
    2. Appearance in details and accuracy.
    3. Values. Your greatest deal tank.
  • DavidN
    • May 2021
    • 3189
    • Los Angeles, CA
    If anyone wants to add a category or put a subdivision into a category, please do so. Again, this is based on the tanks that you own and had made your hands dirty from playing with them :-)
    • DavidN
      • May 2021
      • 3189
      • Los Angeles, CA
      1st place in durability: KV-1
      It runs well with those wide, heavy and durable tracks (I upgraded from a static displayed model to all metal running gears and steel gearboxes. It has big sprockets at the rear. The turret is large enough for easy work. It climbs on everything. I screwed the gearboxes into the base so it is very strong. With its short barrel, I had less issue in IR battle between those buildings.
      • DavidN
        • May 2021
        • 3189
        • Los Angeles, CA
        2nd place durability: T34/85.
        It is well built and runs great in battle. It is simple and durable. Its tracks don't grab the ground as good as the KV-1 but they are still wide enough for a good performance. The on/off switch is easily reached in the driver hatch for the 7.0 version. The turret is also big for easy work inside. Upgrading all the wheels, idlers and sprockets to metal were also easy. I don't have to work or check on it much before taking it to play IR battle.
        Here is the picture of the 1st and 2nd place
        tanks together:
        • DavidN
          • May 2021
          • 3189
          • Los Angeles, CA
          3rd place for durability: Panzer III.
          It’s small and easily maneuvers in battle. Its tracks can be replaced with Toro or Taigen metal tracks. I sent it into battle 3x so far and it had given me no problem. I put it the stock battery (1800mAh) and loaned it to a boy to battle in LA. He ran it (and abused it) for 4 battles. He also ran it during the break times between battles too.
          • DavidN
            • May 2021
            • 3189
            • Los Angeles, CA
            1st place in appearance: King tiger
            Awesome looking. Look just like my 1/35 scale Dragon model.
            • DavidN
              • May 2021
              • 3189
              • Los Angeles, CA
              • DavidN
                • May 2021
                • 3189
                • Los Angeles, CA
                2nd place in appearance: Jagdpanther.
                Such a scary tank destroyer. After fixing the springs in the 2 front wheels to raise the front up, it looks very balance.
                • DavidN
                  • May 2021
                  • 3189
                  • Los Angeles, CA
                  3rd place in appearance: T34/85.
                  I have two Russian Trumpeter T34s. The HL T34 looks very much similar to my Trumpeter models...on the outside of course.
                  • DavidN
                    • May 2021
                    • 3189
                    • Los Angeles, CA
                    1st place in values : Tiger I
                    I got a good deal on a new fully customized tank with barrel recoil for $270
                    • Rubicon99
                      • 3311
                      1. Durability: goes to the KV1 (KV34/85 shown here) is hands down the most durable. The KV can take an immense amount of abuse and come back for more. It’s big can be made to be very heavy and with upgrades to motors nearly unstoppable off road.
                      2. Appearance, this goes to the T72. It has been in use around the world for 50 years and there are endless options for camo schemes and modifications. This lends it to being able to be made into a relatively interesting model. Shown here in desert theme and a modernized themed.
                      3. Value, this is hands down the T34. It runs extremely well out of the box, reliable, reasonable good off road and needs next to no maintenance. T34s are so easy to drive and reliable that I use them as primary “loaner” tank at IR battle days. The all around reliability and ease of operation make it the best value in the entire HL line up. Shown here in Arab desert theme.
                      4. IR battling. I made this a stand alone section in my ranking because almost all the HL tanks when modified with aftermarket IR receivers are equally good. Although there are two that stand out a little more then the rest. The first is the M41 Walker Bulldog and the second the M4 Sherman. These two tanks consistently do well in IR battles. Don’t ask me what makes them just a little better. It really takes having driven and fought with all the tanks to understand the little nuances of each. Shown here the M41 and M4. NOTE: both these tanks have been modified in appearance from the factory HL scheme.
                      M41 Walker Bulldog
                      M4 Sherman Click image for larger version
                      • SoCalBobS
                        • 2716
                        • Southern California
                        Fun thread, David!
                        Favorites? My primary criteria for this choice would be performance outside. In this light, any tank with wide tracks are good, seeming to be less likely to come off the wheels. This means T-34 & M41 Bulldog tied for first:
ID:	330696Click image for larger version
                        KV-1 (in Zik-20 configuration) and King Tiger tied for second.
ID:	330700Click image for larger version
Name:	King Tiger 10.JPG
                        Honorable mentions for the M26 Pershing. My Panther G is new so it's unrated.
