Heng Long Jagdpanther
  • Ashg1
    • Dec 2021
    • 11
    Hi all
    I have just put some money on a Henglong - Jagdpanther Tank RTR v6.0s, is there anything I should look out for when I first test it?
  • Rubicon99
    • 3311
    Originally posted by Ashg1
    Hi all
    Often the track is not properly seated around the rear idler wheels. Other then that make sure you fully charge or have a fully charged battery ready to go otherwise you can have a under volts system shut down.
    • SoCalBobS
      • 2717
      • Southern California
      There is a sticky thread in the front of this sub-forum that will get you started. Welcome aboard!
      • Ashg1
        • Dec 2021
        • 11
        Thanks!
        • DavidN
          • May 2021
          • 3189
          • Los Angeles, CA
          Jagdpanther is my favorite. I got mine with 6.0S version too a month ago. You should be fine. I ordered the side skirts from Germany. They arrived last weekend. I put them on and have just painted it. No weathering yet.
          • DavidN
            • May 2021
            • 3189
            • Los Angeles, CA
            Oh! Mine came with the tracks hanging down too loose (metal tracks). If yours come the same way. Then here is what I did. There is a little hole in the rear idler. I used the small long Phillip screw driver to turn it loose but not all the way. As the idler connector from the hull became loose, I then rotated it back to increase the tension of the track. If it is the left track, move it to to the direction about 4 o'clock. if it is the right track, move it back to about 8 o'clock. Don't rotate it too far up at 9 or 3 o'clock or the track will hit the hull, and the tank can't run. Have fun!
            • Ashg1
              • Dec 2021
              • 11
              Thanks!
              • Ashg1
                • Dec 2021
                • 11
                Picked it up last weekend, I love it!
