DAS WERK STUG III (TAKOM)
  • DavidN
    • May 2021
    • 3189
    • Los Angeles, CA
    I came home from work today and it was at the front door with the Stug III label at the lower left side.
  • DavidN
    • May 2021
    • 3189
    • Los Angeles, CA
    I unboxed it and there it was with a "thank you" note from Andy.
    • sclui56
      • Mar 2021
      • 415
      • LAX
      Are you keeping this static or using the upper on the HL?
      • DavidN
        • May 2021
        • 3189
        • Los Angeles, CA
        I am going to start working on the upper hull first. I just can't wait to see how much detail it has over the HL. Then I will try to see if it matches the HL lower and make it the RC version the lazy way. I did the same with the upper Trumpeter SU-100 on the HL chassis. I will also watch on youtube to see how Andy built his and see if there is a way to make the lower hull become RC too.
        • sclui56
          • Mar 2021
          • 415
          • LAX
          I also wonder how well it matches with the Taigen PZ3 lower. Looks like you will be busy for a bit.
          • SoCalBobS
            • 2716
            • Southern California
            Yeah, a week at least! 😉 David's a quick worker.
            • DavidN
              • May 2021
              • 3189
              • Los Angeles, CA
              I know that the front of the Pz III doesn't have the additional armor plate with all the nuts and bolts on the Stug III.
              • DavidN
                • May 2021
                • 3189
                • Los Angeles, CA
                As much as I want to open it, I would like to finish the KV85, put a long barrel on my M4 to make it a Firefly, side skirts work on the jagd V and panther. Then I will get to this kit :-)
                • DavidN
                  • May 2021
                  • 3189
                  • Los Angeles, CA
                  LOL, Well I already have the paint scheme in mind. I can also make my own side skirts too :-)
                  • sclui56
                    • Mar 2021
                    • 415
                    • LAX
                    That's fine David, you just multi-task, besides, you probably don't have the discipline to leave the box unopened for long....
                    • DavidN
                      • May 2021
                      • 3189
                      • Los Angeles, CA
                      You are absolutely right. I will wake up early tomorrow morning. While all members in my family are still sleeping as it will be raining outside in Southern CA, I will open it and enjoy studying through it :-)
                      • SoCalBobS
                        • 2716
                        FYI, Andy's Hobby headquarters is showing a 1:16 Panzer III J kit by Das Werk due out in April. You can see his video on Youtube. It has some barrel and armor options...
                        Better stock up on HL Pz III kits!
                        • DavidN
                          • May 2021
                          • 3189
                          • Los Angeles, CA
                          Also, FYI, the upper hull of the Das Werk Stug III does not match with the lower HL hull. I worked on the upper part of the kit yesterday. I will assemble it and will try to install the HL gearboxes into it to see if I can convert it to RC. If it does not work, I can cover the sprocket areas up and make it a displayed model.
                          • DavidN
                            • May 2021
                            • 3189
                            • Los Angeles, CA
                            I tried to work on the lower hull last night. I had successfully installed the HL ML49 gearboxes. I also have to use the HL tracks and HL sprockets just to make it runs right. No need to use the Takom tracks. The guy on Youtube stated that it took him 3 hours to put the Takom track links together :-(. No need to buy a whole HL Stug III just to get that lower hull. It doesn't fit anyway.
                            • DavidN
                              • May 2021
                              • 3189
                              • Los Angeles, CA
                              High speed testing. So far so good.
                              • quitcherbitchen
                                • 923
                                • Altadena, CA
                                Bit confused. You need the lower HL hull or not?
                                • sclui56
                                  • Mar 2021
                                  • 415
                                  • LAX
                                  I think David concluded the HL doesn't mate properly to the Takom, so he is turning the entire Takom from static to RC with HL electronics + gearbox+ sprockets + tracks.
                                  • DavidN
                                    • May 2021
                                    • 3189
                                    • Los Angeles, CA
                                    Yeap! I keep the Takom wheels and idlers on the tank for now since they are still functional.
                                    • DavidN
                                      • May 2021
                                      • 3189
                                      • Los Angeles, CA
                                      Update....The assembly and HL electronic installation are done. It can run. I gave it a front light from my panzer III spare part box. It has the red LED light in the driver view box and a red LED launch flashing light in the muzzle brake. No gun elevation. The reason I had to paint the lower hull because the wheels had 2 parts on the sprue. There were the wheels and there were the tires. I painted the tires black and painted the rest of the lower hull dark yellow. Then I could attach the black tires on to the wheels so I could test the tank if it could run. This was was much easier than painting the tire one by one together with the wheel when the work was done.
                                      • sclui56
                                        • Mar 2021
                                        • 415
                                        • LAX
                                        Looks great, are you going to swap in a Mato Notek? Did they include the metal barrel?
