Tamiya 1/16 Centurion build and field test.
  • Rubicon99
    • 3316
    Originally posted by DavidN
    May I see decal set sheet and the paint scheme pattern page? Thx!
    Decal sheet. Click image for larger version
    • DavidN
      • May 2021
      • 3203
      • Los Angeles, CA
      Thank you!
      • Rubicon99
        • 3316
        I was asked to show a size comparison and just how big the Centurion is. Shown here next to my Tamiya Pershing and Abrams.
        Note: The Centurion is far from finished in these photos and just now starting system check (the barrel is a temporary 105mm L7 and will be replaced shortly with a fully machined version). I videoed the systems check and it is on my Instagram @ fsttanks. Feel free to take a look.
ID:	335259Click image for larger version
ID:	335260Click image for larger version
        • DavidN
          • May 2021
          • 3203
          • Los Angeles, CA
          For me....Without having its tracks on, comparison doesn't look quite right yet :-) Looking forward to see it having it tracks on and posing next to your Merc for sizing up
          • Rubicon99
            • 3316
            Build photos continued.
ID:	335295Click image for larger version
ID:	335294Click image for larger version
ID:	335293Click image for larger version
            A small change at this step indicated by the tip of the screwdriver. I swapped out the supplied bushings for bearing. The bearing are the same size as used in the road wheels. This IMO made the mantle movement much smoother.
            • Rubicon99
              • 3316
              Finished up the last major parts and gave the Centurion its first powered driving test (now on Instagram @ fsttanks). Below are the last two steps I will be coving from the manual as the rest of the work is personal detailing parts and custom add ons.
ID:	335306Click image for larger version
ID:	335307Click image for larger version
              • Nfafan
                • Nov 2020
                • 75
                My 1/25th kit has these same decals. Looks to be able to mark up 1 of 4 tanks in the KW. I’ve seen pics of an old 1/25th kit instructions and it had markings options for several countries including the IDF.
                • Rubicon99
                  • 3316
                  Progress photos.
                  100% operational and function tested. Heading to paint and detailing next. (Shown here with the removable Tamiya IR receiver installed)
ID:	335514Click image for larger version
ID:	335513Click image for larger version
                  • DavidN
                    • May 2021
                    • 3203
                    • Los Angeles, CA
                    Marvelous
                    • DavidN
                      • May 2021
                      • 3203
                      • Los Angeles, CA
                      Does it run as fast as your Leopard (the one you brought to the LA Battle)?
                      • Rubicon99
                        • 3316
                        That was Rich’s Leopard not mine.
                        The Centurion is about as fast as a Pershing. It’s not what I would call fast by any means. It has adequate speed for battle fields like San Diego or DAK and is plenty fast for city type battle fields like LA or AAF.
                        • Rubicon99
                          • 3316
                          More test videos are now up on my Instagram @ fsttanks.
                          • oldwolf
                            • Dec 2020
                            • 266
                            This is a great project thread. Thanks for all your work on it.
                            By the way, what can all the buttons on the transmitter that came with the tank be set to control on it?
                            • SoCalBobS
                              • 2754
                              • Southern California
                              I was curious about that also. I found partial info online:
                              Adopts a 4ch transmitter equipped with function buttons
                              The RC mechanism uses a 2.4GHz radio set that can be easily enjoyed by multiple units without worrying about interference. The stick-type 4ch transmitter is equipped with 10 function buttons that correspond to the various functions of the tank with one push, as well as the trim lever for each channel. In addition, various settings such as button functions on the LCD screen, channel swap that can change the channel position, and servo endpoint adjustment are possible, and various information can be displayed. It is also characterized by being able to store up to 5 models of uniquely set data.
                              • Rubicon99
                                • 3316
                                Yep does all those things. I was going to run my DX8e in this tank but after using the supplied radio I see no reason it’s actually pretty decent for a tank controller.
                                • Rubicon99
                                  • 3316
                                  Just to be clear the Tamiya radio does not come with the US version of the Centurion kit.
                                  Bob hit all the high points in function does everything he listed.
                                  • Rubicon99
                                    • 3316
                                    Tamiya 1/16 Centurion.
                                    BASIC tan paint on and some “dry fitted” kit test placement. Next up is detailing parts, weathering and then trials course testing.
                                    • sclui56
                                      • Mar 2021
                                      • 415
                                      • LAX
                                      Thanks for sharing the build, it is a very good looking vehicle!
                                      • DavidN
                                        • May 2021
                                        • 3203
                                        • Los Angeles, CA
                                        It is nice to have a new tank model in our hobby :clap:. Thank you R99 for the 1st built!
                                        • DavidN
                                          • May 2021
                                          • 3203
                                          • Los Angeles, CA
                                          I have just seen the step # in the manual of this last picture. The step # is at 75 :astonished:. For the Jagdpanzer IV that I built, it has 46 steps. The KT I that finished only has 37 steps. Oh boy, I will be quite busy when I receive this tank in March.
