February 5th LA Tank Battle day
  • #21
ID:	336634Click image for larger version
ID:	336632Click image for larger version
    • #22
      I like the one with the Panther in front of the Reichstagg
      • #23
ID:	336639Click image for larger version
ID:	336637Click image for larger version
        • #24
ID:	336641Click image for larger version
ID:	336642Click image for larger version
          • #25
ID:	336645Click image for larger version
ID:	336646Click image for larger version
            • #26
ID:	336650Click image for larger version
              • #27
ID:	336653Click image for larger version
                • #28
ID:	336656Click image for larger version
ID:	336657Click image for larger version
ID:	336658Click image for larger version
                  • #29
ID:	336661Click image for larger version
                    • #30
ID:	336664Click image for larger version
                      • #31
                        THE END
                        • #32
                          Oh! And to the wonderful member who gave me this little gift....Thank you again :-)
                          • #33
                            Looks like great fun and a great looking bunch of tanks Thanks for sharing
                            • #34
                              What a great set of pictures. It looks like you all had a great time.
                              Nice to see a few infantry deployed. Has anyone come up with a way to simulate them in the battles?
                              One thing puzzles me. I see what seems to be the same tank, sometimes with a LegoDei ir reciever and in other pictures it is using a Tamiya ir reciever. Were the owners just seeing which they liked better? Or is there enough difference that battles require all participating to use one or the other in order to be fair? Is one better for congested terrain where ranges are short and the other better for open ground with longer ranges?
                              • #35
                                I think what you are seeing is folks trying out new receivers. Lego DEI was at the event selling his products. I personally bought a couple more Lego IR receivers and like others was swapping them in and out of my tanks.
                                The Lego DEI receivers are actually more sensitive to receiving hits than the Tamiya IR receivers. They are also lower profile. So for city fighting they are slightly better because they allow for your tank to use cover more effectively yet will take hits easily when you expose your tank.
                                • #36
                                  Wow, a lot more tanks compared to the time I was there! What fun!
                                  • #37
                                    Thanks for the response. So there isnt a standard height above turret and/or obstructions such as open hatches or machine guns?
                                    • #38
                                      I think if you use the figures around the mines that would be like a small infantry squad level interaction Vs the just drive by and get clobbered by the mine.
                                      • #39
                                        There is no height or obstruction requirement as long as the IR receiver can be hit from 360 degrees at a distance of at least 15-20 feet. That is the general rule of thumb. Must note: that the IR bulbs (LegoDEI) and or internal mirror (Tamiya) of the receiver should not be “off set”/“twisted” in a way that does not take direct frontal turret hits past 20 feet. This would give said tank an unfair advantage and be considered cheating. It is easy to spot and we do call these players out.
                                        The Tamiya IR receiver are old technology and it is much easier to block incoming IR signals from being registered so they are set higher on the tanks. The LegoDEI receivers are far more sensitive being they have four IR receiver bulbs vs the one the Tamiya uses. As such they can be set much lower and still receive hits just as reliably as the high mounted Tamiyas.
                                        • #40
                                          There is no height or obstruction requirement as long as the IR receiver can be hit from 360 degrees at a distance of at least 15-20 feet. That is the general rule of thumb. Must note: that the IR bulbs (LegoDEI) and or internal mirror (Tamiya) of the receiver should not be “off set”/“twisted” in a way that does not take direct frontal turret hits past 20 feet. This would give said tank an unfair advantage and be considered cheating. It is easy to spot and we do call these player out.
                                          I like that you all base your standards in practical functionality tests. So, detection bulbs facing direct front sides and back for legodei units. And low profile mounting is ok. Nice, makes it much less obtrusive.
                                          Thanks for your response.
