LA TANK BATTLEDAY SATURDAY, APRIL 02, 2022
  • DavidN
    • May 2021
    • 3203
    • Los Angeles, CA
    Just a reminder to get your tanks serviced and charged up for the next battleday. Gates open at 10:00. We'll set-up the battlefield and get battling shortly afterward.
    Battledays have been moved to the 1st SATURDAY of the month from now on.
    The battleday event is held at the American Military Museum located at 1918 Rosemead Blvd., South El Monte, CA 91733.
    Parking and access is via the museum's back gate located on the South side of the museum's property (enter at the small gate off Rosemead (located between the museum's back fence, and the fenced off carnival site)).
    While the gate may appear locked, it should not be. Just remove the lock, drive through, and close the gate (replace the lock like you found it) afterward. DO NOT LOCK THE GATE! We are required to keep the gate closed but unlocked (while battling) pursuant to an L.A. County request to restrict access via the gate.
    We hope to see you all there.
    Admission to the museum is required ($5.00 per person, all proceeds go to the museum). Please see the museum's website for additional information.
  • Rubicon99
    • 3316
    Unfortunately I may be missing this one. 🙁🙁
    • quitcherbitchen
      • 928
      • Altadena, CA
      I am too. I have to help unpack the house. Wife would be quite upset if I ditched her. LOL
      • RichJohnson
        • 1276
        Are you ready for Axis and Allies
ID:	341054Click image for larger version
        • DavidN
          • May 2021
          • 3203
          • Los Angeles, CA
          M4s against Pz4s :-)
          • Rubicon99
            • 3316
            Just a small sampling of the available combat ready “multi national force” to assist the good guys(?).
            Click image for larger version  Name:	5129EA57-D285-48B2-B79F-6AD35351A195.jpeg Views:	0 Size:	165.5 KB ID:	341097
            • DavidN
              • May 2021
              • 3203
              • Los Angeles, CA
              Even though most of my Allies armors are not battle ready. I hope they will be in the near future..
ID:	341125Click image for larger version
              • DavidN
                • May 2021
                • 3203
                • Los Angeles, CA
                And then there are my Panthers, King Tigers, Leopards and ...... :-)
                • DavidN
                  • May 2021
                  • 3203
                  • Los Angeles, CA
                  City set up
                  • DavidN
                    • May 2021
                    • 3203
                    • Los Angeles, CA
                    Display
ID:	341322Click image for larger version
ID:	341323Click image for larger version
                    • DavidN
                      • May 2021
                      • 3203
                      • Los Angeles, CA
                      Check out hiding spots
ID:	341326Click image for larger version
                      • DavidN
                        • May 2021
                        • 3203
                        • Los Angeles, CA
ID:	341329Click image for larger version
ID:	341330 Attendees
                        • DavidN
                          • May 2021
                          • 3203
                          • Los Angeles, CA
ID:	341332Click image for larger version
                          • DavidN
                            • May 2021
                            • 3203
                            • Los Angeles, CA
                            • DavidN
                              • May 2021
                              • 3203
                              • Los Angeles, CA
                              After lunch, we had our Click image for larger version
ID:	341338Click image for larger version
ID:	341339 WWII battles between the Axis and Allies.
                              • DavidN
                                • May 2021
                                • 3203
                                • Los Angeles, CA
                                • DavidN
                                  • May 2021
                                  • 3203
                                  • Los Angeles, CA
                                  It was fun fighting side by side with tanks that had the same insignias :-)
ID:	341343Click image for larger version
ID:	341344Click image for larger version
ID:	341345Click image for larger version
                                  • DavidN
                                    • May 2021
                                    • 3203
                                    • Los Angeles, CA
                                    I need some experienced opinions. Is it good or bad in term of IR reception to have this tank color set up for IR battle? I am just curious. Thank you!
                                    • Rubicon99
                                      • 3316
                                      It will not make any difference to the tank receiving hits. It could have issues with IR “splash” effect on other tanks that might be next to it.
                                      • DavidN
                                        • May 2021
                                        • 3203
                                        • Los Angeles, CA
                                        I see. I better paint it then. Thank you!
