Official Torro 1/16 Scale German Leopard 2A6 Battle Tank RTR Thread
    • 8233
    1/16 Scale German Leopard 2A6 Battle Tank from Torro - RTR - TOR1113889001
    The Leopard 2 is a main battle tank developed by Krauss-Maffei in the 1970s for the West German Army. The tank first entered service in 1979 and succeeded the earlier Leopard 1 as the main battle tank of the German Army. It is armed with a 120mm smoothbore cannon, and is powered by a V-12 twin-turbo diesel engine. Various versions have served in the armed forces of Germany and 12 other European countries, as well as several non-European nations.
    This version is delivered as RTR (Ready to Run), meaning it is fully functional out of the box.
    All Metal Track System
    All of Torro's "Pro-Edition" tanks feature full metal drive systems. Single track links are connected with steel pins, propelled by metal drive sprockets and riding over metal road wheels and idler. Confidently conquer terrain with these durable metal tracks!
    Exhaust Effect
    Enjoy the added scale realism that an exhaust provides.
    Heavy Metal Castings
    Hoist hooks, spare track links and even simulated "welds" are reproduced in cast metal! The iconic "Zimmerit" coating applied by tank crews to repel magnetic mines is also molded into the plastic upper hull for additional period accuracy.
    IR Battle Ready
    Engage in friendly infrared ("IR") combat with other tanks using Torro's proprietary IR Battle System, both inflicting hits upon and receiving hits from opponents! Sounds and action signal each hit, until the 5th hit disables the tank. After 10 seconds, the disabled tank restarts and can rejoin the fight!
    Onboard Charging
    Torro's convenient onboard charging system eliminates the hassle of removing batteries after every driving session. Safely charge the onboard NiMH battery by plugging the included charger's plug into the tank's concealed charge port.
    Superb Scale Fidelity
    Molded details, metal cast parts, brass photo-etched parts, and functional elements such as opening hatches all elevate this RC model to the next level, making it a perfect display piece when it's not powering through the battlefield outside.
    360 Degree Turret
    Fully rotate the metal turret 360 degrees, and move the all-metal barrel up and down to train on your target. Torro's integrated drive electronics gives you complete proportional control to translate your precise inputs to all axe of movement. Drive, turn, traverse, train, and fire!
    RTR
    The convenience of "Ready to Run" (RTR) allows new players to join the world of RC Tanks with ease!
    Features:
    • 70%+ metal parts including turret, main barrel, tracks and drive system
    • 360 degree turret rotation
    • Barrel Recoil with Muzzle Flash effect
    • Realistic Torsion Bar suspension system
    • Metal lower hull, drive wheels, idler wheels, and road wheels
    • Single pad metal tracks connected with steel pins
    • Onboard charging system via charge socket
    • Proportional acceleration, steering, turret traverse, and gun movement
    • Realistic sound system and smoke effect generator
    • Fires an invisible IR signal to be used as part of Torro's proprietary Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
    Includes:
    • Torro German Leopard 2A6 1/16 Scale Battle Tank - RTR
    • 7.2V NiMH battery with Tamiya connector
    • 7.2V NiMH battery charger
    • 6-Channel 2.4GHz radio transmitter
    • Infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • Set of small parts and accessories
    • Smoke effect oil (vegetable glycerin)
    • Sturdy wooden crate for transportation and display
    • Complete instruction manual in English and German
    AGE LEVEL: 14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: 1 Hour
    Scale 1:16
    Length 68.7cm / 27.0in
    Width 23.6cm / 9.3in
    Height 20cm / 7.8in
    Weight 8000g / 282oz
    Body Material Metal/Plastic
    Chassis Material Metal
    Track Material Metal
    Bearings Metal Bushings
    Gearbox Gear Material Steel
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Bogie
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler No
    Turret Rotation 360 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V 1800mAh (included)
    Required Radio 6 Channel (included)
    Skill Level Beginner
    Build Time 1 Hour
  • Fred26
    • Jul 2021
    • 6
    Just starting out in Tanks with the Torro German Leopard 2A6 1/16 Scale Battle Tank - RTR. Is there a BB upgrade you can get for the IR version?
    Thanks​
    • DavidN
      • May 2021
      • 3203
      • Los Angeles, CA
      I don't think so. My understanding is that for Torro, they have two different mechanisms inside the turret.
      • Fred26
        • Jul 2021
        • 6
        Thanks for the feedback David.
        • sclui56
          • Mar 2021
          • 415
          • LAX
          It would be much easier to swap out the turret, these come painted or unpainted.
          • MrChef
            • Jan 2023
            • 510
            • New York, Not the city
            Curious if the Torro version comes with 390 motors like the Taigen does? Yes I see the specs but more than once Motions specs have been incorrect in my experience. Taigen has 390 motors with their 4:1 gearset. And often Torro follows suit but I'd like to know for certain. The current Torro offering is IR with barrel recoil/flash and smoke.
            • keilau
              • Mar 2021
              • 1844
              • Windy City
              I suspect that you are correct. The Torro metal Leopard 2A6 needs the 390 motors to run properly. The MotionRC.com marketing department are likely to be lazy and just copy the listing from other brand for the Torro. And they do not read this forum, nor answer specific questions too technical for them.
              The Mabuchi 300 series motors are small. Its torque is directly proportional to the rpm. The metal Torro will need the 25000 rpm 390, not the 15000 rpm 380.
              My experience of adapting the Torro metal lower chassis is very positive. I love how the Leopard 2A6 runs outdoor now.
              https://www.motionrc.com/products/torro-1-16-scale-german-leopard-2a6-metal-chassis-tor1213889006?variant=38101447737529&utm_source=criteo&utm_medium=display&utm_campaign=WebConversion-Dec27,2019&utm_id=204078&cto_pld=NVQxMasGAQBTU1jgnoRSAw Anyone has information on how the road wheels are attached to this
