Official Torro 1/16 Scale German Tiger I Late Heavy Tank RTR Thread
    • 8218
    1/16 Scale German Tiger I Late Heavy Tank from Torro - RTR - TOR1112800105
    The Tiger I, a German heavy tank of World War II, operated from 1942 in Africa and Europe, usually in independent heavy tank battalions. It was designated Panzerkampfwagen VI Ausf H during development but was changed to Panzerkampfwagen VI Ausf E during production. The Tiger I gave the German Army its first armoured fighting vehicle that mounted the 8.8 cm KwK 36 gun (derived from the 8.8 cm Flak 36). 1,347 were built between August 1942 and August 1944.
    Faithfully recreated in 1/16 scale, Torro continues to grow its reputation as a producer of high quality, high functioning RC tanks. This Pro Edition of the German Tiger I features more than 70% metal part construction, a 360 degree rotating turret, a realistic torsion bar suspension, and a barrel recoil and muzzle flash effect that fires in sync with the IR (infrared) battle system. This version is delivered as RTR (Ready to Run), meaning it is fully functional out of the box.
    All Metal Track System
    All of Torro's "Pro-Edition" tanks feature full metal drive systems. Single track links are connected with steel pins, propelled by metal drive sprockets and riding over metal road wheels and idler. Confidently conquer terrain with these durable metal tracks!
    Exhaust Effect
    Enjoy the added scale realism that an exhaust provides.
    Heavy Metal Castings
    Hoist hooks, spare track links and even simulated "welds" are reproduced in cast metal! The iconic "Zimmerit" coating applied by tank crews to repel magnetic mines is also molded into the plastic upper hull for additional period accuracy.
    IR Battle Ready
    Engage in friendly infrared ("IR") combat with other tanks using Torro's proprietary IR Battle System, both inflicting hits upon and receiving hits from opponents! Sounds and action signal each hit, until the 5th hit disables the tank. After 10 seconds, the disabled tank restarts and can rejoin the fight!
    Onboard Charging
    Torro's convenient onboard charging system eliminates the hassle of removing batteries after every driving session. Safely charge the onboard NiMH battery by plugging the included charger's plug into the tank's concealed charge port.
    Superb Scale Fidelity
    Molded details, metal cast parts, brass photo-etched parts, and functional elements such as opening hatches all elevate this RC model to the next level, making it a perfect display piece when it's not powering through the battlefield outside.
    360 Degree Turret
    Fully rotate the metal turret 360 degrees, and move the all-metal barrel up and down to train on your target. Torro's integrated drive electronics gives you complete proportional control to translate your precise inputs to all axe of movement. Drive, turn, traverse, train, and fire!
    RTR
    The convenience of "Ready to Run" (RTR) allows new players to join the world of RC Tanks with ease!
    Features:
    • 70%+ metal parts including turret, main barrel, tracks and drive system
    • 360 degree turret rotation
    • Barrel Recoil with Muzzle Flash effect
    • Realistic Torsion Bar suspension system
    • Metal lower hull, drive wheels, idler wheels, and road wheels
    • Single pad metal tracks connected with steel pins
    • Onboard charging system via charge socket
    • Proportional acceleration, steering, turret traverse, and gun movement
    • Realistic sound system and smoke effect generator
    • Fires an invisible IR signal to be used as part of Torro's proprietary Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
    Includes:
    • Torro German Tiger I Late 1/16 Scale Heavy Tank - RTR
    • 7.2V NiMH battery with Tamiya connector
    • 7.2V NiMH battery charger
    • 6-Channel 2.4GHz radio transmitter
    • Infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • Set of small parts and accessories
    • Smoke effect oil (vegetable glycerin)
    • Sturdy wooden crate for transportation and display
    • Complete instruction manual in English and German
    AGE LEVEL: 14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: 1 Hour
    Scale 1:16
    Length 54cm / 21.2in
    Width 23.2cm / 9.1in
    Height 19.5cm / 7.6in
    Weight 6800g / 240oz
    Body Material ABS Plastic
    Chassis Material Metal
    Track Material Plastic
    Bearings Metal Bushings
    Gearbox Gear Material Steel
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Bogie
    Sprocket Plastic
    Road Wheels Metal
    Idler Wheel Plastic
    Adjustable Idler No
    Turret Rotation 360 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V 1800mAh (included)
    Required Radio 6 Channel (included)
    Skill Level Beginner
    Build Time 1 Hour
  • TopD
    • Nov 2024
    What are the 2 switches on the blue box for?
    • tank_me
      • Feb 2022
      • 1186
      Inside the tank? You mean this blue box?
      If so, this is the instruction doc:
      • MrChef
        • Jan 2023
        • 502
        • New York, Not the city
        tank_me shows the only blue box with switches inside the Torro Tiger I. It is for setting the Tanks IR battle send/receive modes. FYI it will work with Heng Long tanks but not properly or accurately. I can not attest to it working/registering with Tamiya though.
        • tank_me
          • Feb 2022
          • 1186
          I have one installed on my Torro Sturmtiger and it does indeed take and give hits on the Tamiya protocol setting just fine.
          • MrChef
            • Jan 2023
            • 502
            Nice. It does not play well with the Heng Long system. It will give and take hits but the Heng Long has the advantage.
            • tank_me
              • Feb 2022
              • 1186
              The Tamiya protocol is the same protocol the HL is using now. I didn't do any long distance testing, but the Sturmtiger (V3 MFU) worked just fine with the HL using the Torro "apple". It's a smaller, newer version than the one that comes stock with the Taigen/Torro IR tanks. The emitter is circled in the pic and the small apple is pictured. I painted the green on the base of the apple just so it didn't look so dorky, but it doesn't block the sensor on top. The top sensor actually has no obstructions 360 degrees. I didn't change out the IR LED or put it in a tube yet as I just wanted to experiment with it on the field this past battle day. I was quite happy with the performance of the Torro IR signal converter. Eventually I will do some work on the Sturmtiger to make it a HL board, but it's low on the project list as it is a running tank and battle ready.
              • MrChef
                • Jan 2023
                • 502
                I'll run some tests again before I do the TK 7.0 swap but the last time I messed with the Torro IR Vs. the Heng Long, The Torro would take 5 or 6 hits from the Heng Long and shudder spastically then shut down but the Heng Long would take up to 14 or 15 hits before it would register dead and shut down. This was at very close range indoors.
                • keilau
                  • Mar 2021
                  • 1836
                  • Windy City
                  Originally posted by Aros
                  [CENTER][B]1/16 Scale German Tiger I Late Heavy Tank from Torro - RTR - TOR1112800105
                  Scale 1:16
                  Sprocket Plastic
                  Road Wheels Metal
                  Idler Wheel Plastic
                  Adjustable Idler No
                  Lights Yes
                  Sound Yes
                  Exhaust Effect Yes
                  IR Battle Ready Yes
                  Track Recoil Yes
                  Build Time 1 Hour
                  What is the design philosophy to use plastic tracks, sprockets and idler wheels on a metal chassis tank?
                  ​​​​​​​What is the design philosophy to use plastic tracks, sprockets and idler wheels on a metal chassis tank?What kind of plastic do Torro use on this Tiger 1? Could that be some kind of resin or nylon?
                  • MrChef
                    • Jan 2023
                    • 502
                    It's incorrect. All the running gear on this tank is metal.
                    • keilau
                      • Mar 2021
                      • 1836
                      • Windy City
                      It's incorrect. All the running gear on this tank are metal.
                      I was just quoting the original Post #1 by Aros . I hope that this old 2022 Official post can be corrected.
                      My old 2004 Heng Long Tiger 1 is still in pieces to be fixed someday. It has non-HL metal gear and track.
                      • MrChef
                        • Jan 2023
                        • 502
                        Yeah unfortunately there's more than one tank on the sales site that have incorrect listings. And this one is still listed as you shared. I had a similar issue when I picked up the Panther G Pro from Motion and it listed metal road wheels and they in fact came plastic. I contacted Motion and they just said was a mistake.
                        I have this Torro Tiger I late from Motion RC so I can confirm that the road gear is all metal.
