Official Torro 1/16 Scale German Panther F Unpainted Medium Tank RTR Thread
    • 8218
    Unpainted 1/16 Scale German Panther F Medium Tank from Torro - RTR - TOR1113879101
    The Panther is a German medium tank deployed during World War II on the Eastern and Western Fronts in Europe from mid-1943 to the war's end in 1945. It was designated as the Panzerkampfwagen V Panther until 27 February 1944, when Hitler ordered that the Roman numeral "V" be deleted. Contemporary English language reports sometimes refer to it as the "Mark V".
    This version is delivered as RTR (Ready to Run), meaning it is fully functional out of the box, but it is UNPAINTED, giving modelers more freedom to detail, paint, and weather their model to their final preference. For the pre-painted version, visit here.
    Durable Tracks
    Confidently conquer terrain with durable tracks that are easy to service. Professional Versions feature metal tracks.
    Independent Suspension and Steel Geared Gearbox
    Reliable steel geared gearboxes transfer power while independent suspension provide traction over rough surfaces.
    Omnidirectional Proportional Control
    The latest generation Multi-Function Control Board (MFCB) provides smooth driving response and personalized configuration options.
    IR Battle Ready
    Engage in friendly infrared ("IR") combat with other TK6-equipped tanks, both inflicting hits upon and receiving hits from opponents! Sounds and action signal each hit, until the 5th hit disables the tank. After 10 seconds, the disabled tank restarts and can rejoin the fight!
    Unpainted Version
    Decorate, detail, and weather your model to your specific version and taste. Utilize your painting skills for a truly one-of-a-kind model!
    Scale Detail
    The perfect balance of scale detail and practical RC Tanking, each Torro tank arrives factory painted and includes Cosmetic Accessory Parts to further enhance the tank's realism.
    • Latest Generation Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed, and low-speed modes, etc.
    • Smoke effect (On/Off)
    • Headlights and Brake lights (On/Off)
    • Volume (five settings including Off)
    • Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
    • Track Recoil (Three settings from low, medium, and high) -This shudders the tank briefly rearward to simulate recoil when firing the main cannon
    • Fires an invisible IR signal to be used as part of Torro’s Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
    • Independent suspension on all road wheels
    • Torro German Panther F Unpainted 1/16 Scale Medium Tank - RTR
    • 2S 7.4v 1800mAh Li-ion battery with Tamiya connector
    • 2S USB LiPo/Li-ion battery charger
    • 6-Channel 2.4GHz radio transmitter
    • Magnetic Infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • 2x spare track links
    • Smoke oil
    • Complete instruction manual
    AGE LEVEL: 14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: 1 Hour
    Scale 1:16
    Length 54.5cm / 21.5in
    Width 21cm / 8.2in
    Height 18cm / 7.0in
    Weight 5700g / 201oz
    Body Material Metal/Plastic
    Chassis Material Metal
    Track Material Metal
    Bearings Metal Bushings
    Gearbox Gear Material Steel
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Bogie
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler No
    Turret Rotation 360 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V 1800mAh (included)
    Required Radio 6 Channel (included)
    Skill Level Beginner
    Build Time 1 Hour
  • DavidN
    • May 2021
    • 3200
    • Los Angeles, CA
    A member in our SoCal Tank Club sold me this mess for $100. I gathered parts and finally get it in form for IR battle. I searched around the web to find a good camouflage scheme for it. I then remembered I had a 1/72 scale Dragon model on display somewhere. My project for this week is to paint the 1/16 similar to the 1/72 scale.
Name:	Screenshot 2026-04-26 at 06-45-39 IMG_1691.jpg (JPEG Image 2880 × 2160 pixels) — Scaled (41_).png
ID:	449305 Click image for larger version
    • Rob59
      • May 2026
      • 25
      • Netherlands, Europe.
      ​ Mine, with homemade, detachable alu side skirts, Zusatzpanzerung on the motordeck and on the turretroof
      • Rob59
        • May 2026
        • 25
        In the original pics in the first post, you may have noticed that the sprocketwheels are too low compared to the real thing back then!
        Because of the metal lower hull it is almost impossible to put the spr.wheels higher, so the only thing you could do, to come close to the originals, is making the roadwheels sit lower!
        This can be done by bending the torsionbar suspension to 45 degrees.
        In this way you lower the roadwheels which makes the spr.wheels look higher.
        That‘s what I did on most of my Panthers and Jagdpanthers.
        Looks way better, at least that‘s my opinion.
        Rob.
        • Rob59
          • May 2026
          • 25
ID:	449435 I just noticed, the pics I posted from my side skirts, are not shown in this thread anymore.
          At least, I cannot see them anymore on my cell phone.
          Strange….
          I post 2 new ones, lets see for how long they last on here…
          • DavidN
            • May 2021
            • 3200
            • Los Angeles, CA
            Done. It is ready for the dirt at the battlefield next weekend.
ID:	449641 Click image for larger version
ID:	449642 Click image for larger version
ID:	449643 Click image for larger version
ID:	449644 Click image for larger version
ID:	449645 Click image for larger version
