The Panther is a German medium tank deployed during World War II on the Eastern and Western Fronts in Europe from mid-1943 to the war's end in 1945. It was designated as the Panzerkampfwagen V Panther until 27 February 1944, when Hitler ordered that the Roman numeral "V" be deleted. Contemporary English language reports sometimes refer to it as the "Mark V".
This version is delivered as RTR (Ready to Run), meaning it is fully functional out of the box, but it is UNPAINTED, giving modelers more freedom to detail, paint, and weather their model to their final preference. For the pre-painted version, visit here.
Durable Tracks Confidently conquer terrain with durable tracks that are easy to service. Professional Versions feature metal tracks. |
Independent Suspension and Steel Geared Gearbox Reliable steel geared gearboxes transfer power while independent suspension provide traction over rough surfaces. |
Omnidirectional Proportional Control The latest generation Multi-Function Control Board (MFCB) provides smooth driving response and personalized configuration options. |
IR Battle Ready Engage in friendly infrared ("IR") combat with other TK6-equipped tanks, both inflicting hits upon and receiving hits from opponents! Sounds and action signal each hit, until the 5th hit disables the tank. After 10 seconds, the disabled tank restarts and can rejoin the fight! |
Unpainted Version Decorate, detail, and weather your model to your specific version and taste. Utilize your painting skills for a truly one-of-a-kind model! |
Scale Detail The perfect balance of scale detail and practical RC Tanking, each Torro tank arrives factory painted and includes Cosmetic Accessory Parts to further enhance the tank's realism. |
- Latest Generation Multi-Function Control Board (MFCB)
- Proportional acceleration, steering, turret traverse, and gun elevation/depression
- Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed, and low-speed modes, etc.
- Smoke effect (On/Off)
- Headlights and Brake lights (On/Off)
- Volume (five settings including Off)
- Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
- Track Recoil (Three settings from low, medium, and high) -This shudders the tank briefly rearward to simulate recoil when firing the main cannon
- Fires an invisible IR signal to be used as part of Torro’s Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
- Independent suspension on all road wheels
- Torro German Panther F Unpainted 1/16 Scale Medium Tank - RTR
- 2S 7.4v 1800mAh Li-ion battery with Tamiya connector
- 2S USB LiPo/Li-ion battery charger
- 6-Channel 2.4GHz radio transmitter
- Magnetic Infrared (IR) battle system receiver
- Painted cosmetic accessory parts
- Adhesive decal sheet
- 2x spare track links
- Smoke oil
- Complete instruction manual
- Six (6) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (6 Pack)
AGE LEVEL: 14 and up
SKILL LEVEL: Beginner
BUILD TIME: 1 Hour
| Scale | 1:16 |
| Length | 54.5cm / 21.5in |
| Width | 21cm / 8.2in |
| Height | 18cm / 7.0in |
| Weight | 5700g / 201oz |
| Body Material | Metal/Plastic |
| Chassis Material | Metal |
| Track Material | Metal |
| Motors | Two 380 motors (28x37mm) |
| Bearings | Metal Bushings |
| Gearbox Gear Material | Steel |
| Adjustable Gear Ratio | Fixed |
| Differential Type | Gear |
| Suspension Type | Bogie |
| Sprocket | Metal |
| Road Wheels | Metal |
| Idler Wheel | Metal |
| Adjustable Idler | No |
| Turret Rotation | 360 Degrees |
| Lights | Yes |
| Sound | Yes |
| Exhaust Effect | Yes |
| IR Battle Ready | Yes |
| Airsoft BB Launch | No |
| Track Recoil | Yes |
| Cannon Barrel Recoil | Yes |
| Required Battery | 2S 7.4V 1800mAh (included) |
| Required Radio | 6 Channel (included) |
| Skill Level | Beginner |
| Build Time | 1 Hour |
| Recommended Environment | Indoor / Outdoor |
