Can i use my own radio?
  • Woohoo\o/
    • Feb 2020
    • 186
    • Cape coral Florida
    I have a heng long t90 soon to arrive. I own a flysky paladin 18ch radio I'd like to use with my tank. What do I need to convert? Thank you.
  • Rubicon99
    • 3316
    Only the HL radio works with the HL tank control system. To use your transmitter you would have to swap over to an aftermarket tank control system.
    • Woohoo\o/
      • Feb 2020
      • 186
      Thank you so much. I'll find one :)
      • Rubicon99
        • 3316
        Actually the stock control system is pretty darn good and aside from the TX “look and feel” is often preferred by a lot of tankers these days for causal running and battling needs.
        Give it a try stock for a while you might be surprised how much it grows on you or doesn’t.
        • SoCalBobS
          • 2754
          • Southern California
          Keep in mind when you evaluate, aftermarket boards start at $200ish and up.
          • Woohoo\o/
            • Feb 2020
            • 186
            Oh wow that's pricey. Yeah I've owned 4 HL tanks and I did like the stock radio for what it was. I was just hoping all I needed was some sort of adapter to install my rx. Thanks for all your input commanders.
            • SoCalBobS
              • 2754
              They've upgraded incrementally and substantially. The old silver antenna'd 27mhz were pretty crude. Now, they've gone through 2.4ghz versions 5.3, 6, 6.1, 7.0 & 7.1. 6 and above are great. Have a look at the features of newer ones:
              After trying to read in between the Chinese ideographs on the 6.0 and 7.0 instruction sheets, I’ve taken the time to write out my interpretations. I put the info on my phone notepad so I’d have them handy. You’re welcome to try and cut & paste or otherwise copy them. A real good one in the 7.0 list is K & B, which
