HL t90/leopard bearings
  • Woohoo\o/
    • Feb 2020
    • 186
    • Cape coral Florida
    Does anyone know what size (drive) bearings will work for the t90 (tk7) and leopard (tk7) heng long models?
  • ccarley
    • Jun 2022
    • 158
    • Rohnert Park, CA
    On my daughter's Leopard, and my Abrams as well as my Pershing, these bearings fit perfect:
    " uxcell MR128-2RS Deep Groove Ball Bearings 8mm Inner Dia 12mm OD 3.5mm Bore Double Sealed Chrome Steel Blue Seal Z2 10pcs"
    Clay
    • Woohoo\o/
      • Feb 2020
      • 186
      I remember adding bearings to my old TK6 Abrams. It was easy just pop them in. But I see theres a cover over the shaft. Do you have to cut this cover off? Does it pop off? And thanks very much btw.
      • Rubicon99
        • 3311
        That should be the bearings support housing. The new tanks come with them from the factory. It’s the same bearings support that used to be purchased separately.
        • Woohoo\o/
          • Feb 2020
          • 186
          Awesome thanks very much!!!!!
            • 5392
            On some the bearings pop in. On some you unscrew a cover. On some you have to use some modeling skills to build up an area for the bearing to seat.
