Irvine RC Tank Club
  • DavidN
    • May 2021
    • 3203
    • Los Angeles, CA
    The first order of Tongde tanks for members of our club arrived today...As a special treatment for our club, we were able to receive 20% off on our purchases :-)
    • Rubicon99
      • 3316
      Click image for larger version  Name:	IMG_8898.jpg Views:	0 Size:	80.8 KB ID:	391840
      Wonderful news!!!
      Although I really hope you all bought the "metal" versions 🤞🤞. The all plastic TDs have durability issues especially the way they are used in battling here in Ca.
      Also remember if you keep the TD control system they don't fire the IR with the main gun, they fire it with the MG and also don't like to take hits reliably from HL or Tamiya tanks regardless of the IR receiver used. Lastly the lights don't light up when hit.
      I would encourage you to have the members swap out the TD system with a 7.0/7.1 HL system at very least if they are going to battle with other brands.
      • RichJohnson
        • 1276
        Yes, I was playing with my newly arrived m60a3 yesterday and while the TD controller drives well, it sucks for main gun use. You have to stop to fire the gun and it does not shoot IR, only with the machine gun. And the tank doesnt take hits worth a darn. Needs a 7.1 system for sure
        • DavidN
          • May 2021
          • 3203
          • Los Angeles, CA
          Thank you! And yes, we ordered the metal versions.
          • Rubicon99
            • 3316
            That's really good to hear👍👍👍👍.
            Can't wait to see them them out running around.
            • Rubicon99
              • 3316
              If any of your members are interested in a set of brand new chevron metal TD tracks for an M60 I have a set. $45 plus $11 USPS Priority Shipping. These just can of a project I am working on.
ID:	391908 Click image for larger version
              • DavidN
                • May 2021
                • 3203
                • Los Angeles, CA
                • DavidN
                  • May 2021
                  • 3203
                  • Los Angeles, CA
                  A few pictures of our event in Anaheim today.
ID:	392929 Click image for larger version
ID:	392930 Click image for larger version
                  • DavidN
                    • May 2021
                    • 3203
                    • Los Angeles, CA
ID:	392933 Click image for larger version
ID:	392934 Click image for larger version
                    • DavidN
                      • May 2021
                      • 3203
                      • Los Angeles, CA
ID:	392937 Click image for larger version
ID:	392938 Click image for larger version
                      • DavidN
                        • May 2021
                        • 3203
                        • Los Angeles, CA
ID:	392951 Click image for larger version
ID:	392952 Click image for larger version
                        • DavidN
                          • May 2021
                          • 3203
                          • Los Angeles, CA
ID:	392945 Click image for larger version
ID:	392946 Click image for larger version
                          • DavidN
                            • May 2021
                            • 3203
                            • Los Angeles, CA
                            The engineer member in our club made this. Now I can run my tank and record a video without dropping my phone. So happy!
ID:	393106 Click image for larger version
ID:	393107 Click image for larger version
                            • SoCalBobS
                              • 2754
                              • Southern California
                              This is a not to scale battlefield map using the structures and objects available to the Irvine Club. Battles are held in different locations, so all of the objects have to be portable. The gray rectangles are bunkers made from foam. Starting points are usually behind them. Brown ones are houses that have been gathered over time. Green cones are trees that are inserted into the ground. The vertical line of trees represents a no pass line, like a stream. The light grey line represents a road. If one can't be marked out, the positions of the houses indicate it. The brown...lump...is supposed to be a bridge, either an actual structure or a flat strip of something laid down. The red and blue posts are victory spots. One or both can be used, but the field is oriented for an assault from the left to the right. Having an asymmetrical field allows a variety of maneuver possibilities.
                              This is just presented as a starting point for discussion.
                              Click image for larger version  Name:	Forest Crossing.jpg Views:	0 Size:	69.7 KB ID:	393571
                              • RichJohnson
                                • 1276
                                I tried one of these for a drone radio to hold my home and film and it was crazy. Just wait till you realize you have to point your radio at your tank the whole time and watch what you’re doing through the phone. It was a pain so I dumped it. I’m working on another kind of idea for filming tanks but have been to busy with making tank parts to deal with it yet.
                                • DavidN
                                  • May 2021
                                  • 3203
                                  • Los Angeles, CA
                                  We have most of the items shown in your map. Two members are working on the construction of the bridge. The road, we are figuring that out. Hopefully, we will have this setup on 1/28/2024 battle event. Thank you Bob!
                                  • DavidN
                                    • May 2021
                                    • 3203
                                    • Los Angeles, CA
                                    Christmas present from Toucan to our club came a bit late. However, I am happy.
Name:	EMAIL 2023 GIFT FROM TOUCAN.png
