Sounds wierd on the surface, but hear me out. These things have steel gear transmissions, right? And from the factory there isn't even so much as a hint of a whiff of anything remotely in the same zip code as lubricant on those steel gears. Dry as a popcorn fart. I've taken to putting a few drops of SAE30w motor oil on each gear face as well as a drop on each end of the axles they spin on right where they're spinning. In doing so I've found my HL steel gearboxes get a LOT quieter and tend to run smoother. 'Course there's no 'floor' to the gearboxes so I can't fill a few mL in there for a more constant lube supply and any excess just pools in the hull floor somewhere near the battery tray, but even still I feel like it's doing them some favors.
Maybe one of these days I'll design and print some 'floors' for these gaerboxes that can old a little oil, some walls, roof caps, not fully sealed but good enough to keep the bulk of the oil in the gearbox.
Anyone else doin' something similar?
